2003 Trailblazer Climate Control Panel - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-08-2007, 07:27 PM
ken3477 ken3477 is offline
2003 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 4X4
Question 2003 Trailblazer Climate Control Panel
I have replaced my climate control panel with one from a used parts shop.
The one I got was from a 2003 trailblazer or envoy (who knows).
I installed it and it works for mostly everything except the two slider blend controls seem to work the opposite (blue is warmer, red is cooler).
Also, I do not seem to be able to get air to flow thru the floor vents in the
front and nothing to the rear vents. I have heard about a servo calibration or something that needs to be done when swapping controls. Is this true?
What else can be my problem?
Old 11-08-2007, 11:59 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
Pewter Metallic 4.2L I6 2WD
hmmmm
the only thing I can think of... and I dont know if it will work, is to place the vents in the position that will blow hot air. disconnect battery, and then slide the thingy to the red. then reconnect.
maybe this will force it to learn that position.
ive heard of newer cars losing the vent door positions after battery is disconnected.
Old 11-09-2007, 05:18 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Originally Posted by rbarrios View Post
hmmmm
I think I read somewhere here that you must turn everything off after the battery disconnect and then it will recalibrate after about 15 minutes as long as you do not touch anything.
Bill
Let's get a Meet going!
Old 11-09-2007, 09:01 AM
Outback_Jon's Avatar
Outback_Jon Outback_Jon is offline
2002 Chevy TrailBlazer LS
After a battery disconnect, and 2 one hour trips, I still had hot air coming out of my defroster, no matter what the setting on the controls. (Even with everything turned off)
Another battery disconnect for about 20 minutes did the trick and it works fine now.
Old 08-08-2012, 01:23 PM
Mazedave Mazedave is offline
2008 Chevy TrailBlazer LS
Air flow control panel
Hello,
Did the problem start with little or no flow??
Thanks Dave
Old 08-09-2012, 10:59 AM
Ray Dockrey's Avatar
Ray Dockrey Ray Dockrey is offline
2009 Chrysler PT Cruiser
Inferno Red Other 2WD
Just so you know you replied to a thread that is almost 5 years old.
Old 08-09-2012, 12:06 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Old 02-04-2013, 04:30 PM
ecmore ecmore is offline
2003 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
Hello and Help
First off Hello! I am hoping for a little help regarding My 2003 EXT Trailblazer. My rear climate control does not respond to any of the buttons I push. I turn the fan up/down or the temp up/down and it blinks at me then goes off. Any ideas on this?
Similar Threads
Digital Climate Control and Sensors Ben98gs Interior 11 11-27-2009 09:07 PM
Ugrading to Digital Auto Climate Control Smokinjoe719 Interior 4 08-12-2007 08:15 PM
Looking for digital front HVAC control panel Shady Audio and Electronics 6 09-29-2006 12:06 PM
Automatic Climate control chipper Interior 3 09-17-2006 07:12 PM
digital climate control clrobertson General 10 07-12-2006 06:00 PM
