The Ultimate 'Will it Fit' Chart? - Page 63 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Off-Road
Off-Road For suspension, wheel, and tire questions DIRECTLY related to Off-Roading.
Old 05-22-2013, 11:31 AM
blackcoog blackcoog is offline
2004 Chevy TrailBlazer LS
Originally Posted by j_mercado1202 View Post
Sir,
Did you ever experience any issue with your differential, transmission or engine when you put up your 265/65/R17 tires? Hope to hear from you. Thanks.
Its been quite a while since I did my lift and in that time I've run many tire sizes, several wheels, all different weights....including 38's
The only problem I've had was the angle of the CVs makes them wear a little fast.
Absolutely no problems with the engine and trans. No dif problems that weren't already there when I started.... seems pretty much bulletproof.
I've put 60k miles on my rig with the lift and its still strong.
Experience is never a requirement.... as long as you've got logic on your side.
Old 05-22-2013, 05:16 PM
3Green 3Green is offline
2004 GMC Envoy SLT XL
Graphite Metallic 4.2L I6 4X4
Just put 265/65r17 BFG Long Trails on my stock 04 Envoy xl 4x4. They fit and look great. I don't think you could fit anything bigger though.
  #623
Old 06-04-2013, 11:36 AM
Nathan Soley Nathan Soley is offline
2003 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Newcomer to TB's Need some good advice.
Originally Posted by TEFennell4 View Post
If someone, somewhere, somehow could come up with a sticky chart breaking down 'possible tire fit' by "Wheel Size", "Body Lift Needed?", "Suspension Lift Needed?", "Spacers Needed?" and "Custom Mods Needed?" those of us who aspire to go for lifts/tires may be able to quit asking about our specific setup (ahem...I have 16's, planning the BDS suspension lift, open to spacers, and am totally confused )...
As a bonus, does anybody have a good explanation of how height and width affect the need for spacers and lifts? too wide needs a spacer to clear the ball joint and a lift to keep from rubbing the wheel well on compression, and too tall needs a lift to keep from rubbing the wheel well on compression and spacers to keep from rubbing wheel well on turns? It looks like /75 is the beginning of spacer requirements, 275/16 and 275/17 starts to need a suspension lift, and 285+ needs both lifts? Am I on to anything here? I'll update as I can to keep bad info off the top of the thread...
Here's the information I could gather, assuming stock wheels (Thanks to Clayton and The Roadie!):
16"
265/75/16 - needs spacers
285/75/16 (33") - needs spacers, new wheels, suspension and body lifts, cutting/hammering to fit
17"
255/65/17 - OK w/ no lift, spacers, or mods
255/70/17 - needs upper ball joint mod, possible hammering to fit
255/75/17 - needs spacers, upper ball joint mod, possible hammering to fit
265/70/17 - needs spacers, upper ball joint mod, definite cutting/hammering to fit
285/70/17 (33") - needs spacers, new wheels, suspension and body lifts, cutting/hammering to fit
305/70/17 (34") takes all of the above, plus total dedication to being *the* tallest TB of us all. (JamesDub)
So i guess my question is what is the biggest tire i can go with an '03 trailblazer (LT 4x4) with a 2" body lift, front strut 1.5" lever, a 1.5" wheel spacer, on stock 16" wheels. Maybe someone can show me some pics of their TB with similar mods and larger tires. Like i said im new to TB's and would like some good advice.
  #624
Old 06-04-2013, 12:44 PM
Shdwdrgn's Avatar
Shdwdrgn Shdwdrgn is offline
2004 Chevy TrailBlazer LT
My advice would be to go browse http://forums.offroadtb.com/ and check out the build threads. You'll find the best variety of options there, and plenty of pics to show how the vehicles look while in-progress and completed.
What is a front strut lever? I've never heard of that mentioned before, and am thinking this may not be an option on our platform?
WAAG centerguard, Custom CAI, front shims, quad headlights
South Chapter Member
  #625
Old 06-04-2013, 12:55 PM
Black 4.2L I6 4X4
16"
17"
Sorry I meant to say leveler. I need that little oommff to get my front end up. thank you for the link!
  #626
Old 03-10-2014, 12:46 PM
bcschanen bcschanen is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Just wanted to make a note for those looking:
265/70/16 Michelin LTX M/S2 tires on my 2006 LS 4.2 4x4 with NO modifications.
They fit and I've had no problems, however there is evidence of microscopic rubbing on that upper ball joint. Clearance is probably about 1/4". I've put about 10,000 miles on these tires so far in hot and cold weather, on and off road, have taken them up to 108mph, and have had no issues. Love these tires. I'm pretty sure they're the widest & tallest tire possible on this 16" wheel without modifications.
  #627
Old 05-26-2014, 01:08 PM
jeepsterwannabe jeepsterwannabe is offline
2006 Chevy TrailBlazer LT
So, has anyone determined the biggest tire a stock TB can wear without lifts, spacers, cutting, etc. ??
2006 TB, 4WD, off road bumpers by
  #628
Old 05-26-2014, 02:27 PM
If you want to go with the 265 width, then the tires I posted above are the largest. Again, they only have about 1/4" of clearance so be cautious if using a different tire brand of the same size. I can only speak for the michelins that I have.
  #629
Old 05-27-2014, 10:49 AM
I have always preferred tall and narrow rather than lots of width. And since tire sizing was invented by the same person who invented women's pant sizes, (i.e. random female= "I am a size zero" me= "So you don't exist?"), I guess I will be playing with numbers and calculators.
  #630
Old 08-19-2014, 07:37 PM
ttemple96's Avatar
ttemple96 ttemple96 is offline
2003 Chevy TrailBlazer LTZ
I have 18's and two track with my Tb all the time. I want to get a set of 17's tho and I want them to have some nice offset anyone know a nice (wide look) offset I can go ?
Tags
chart, tire chart, will it fit
Similar Threads
Thermostat repair- how to- pics included rbarrios The 02-09 "How-To" and DIY Section 349 10-10-2016 09:28 PM
Uh-Oh....Looky here! 85vette Latest GM News 21 04-18-2008 01:54 PM
GMs Future Fleet by Fleet.. We all knew it was going to happen Chris Foresta Latest GM News 5 08-03-2007 10:41 AM
Shudder, Rocking Motion, Binding, Feels Like Vehicle is Stuck in 4WD mickdigler 02-09 Vortec 4.2L I-6 Engine and Drivetrain 9 10-02-2006 10:38 AM
