4 low blinking? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 12-24-2005, 01:25 AM
chasmanz28's Avatar
chasmanz28 chasmanz28 is offline
2008 SAAB 9-7x
Summit White 5.3L V8 AWD
4 low blinking?
i switched to 4 low putting my TB up on ramps and it just kept blinking but never went to 4 low is there a problem?
Quick reply to this message
Old 12-24-2005, 01:39 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Are there any lights on?
Also, on another note, why did you try to put it into 4LO to put it on some ramps? Wouldnt 4HI have worked too?
Did you engage it properly, you need to do something different when going into 4LO over the rest, there is a special precedure to use. Cant recall what it is, but there is a thread about it. Also, check the owners manual, it tells you how to do it.
Old 12-24-2005, 01:45 AM
chasmanz28's Avatar
2008 SAAB 9-7x
just wanted to put it in 4 low never used it before, i didnt check to see if there was a certain precedure that i had to do, as far as light the 4 high was on with the 4 low light just blinking
Old 12-24-2005, 02:33 AM
jomschwa's Avatar
jomschwa jomschwa is offline
2003 Chevy TrailBlazer LT
4.2L I6 4X4
Without going outside at 1:30AM and checking the owners manual, I think you need to have the truck stopped and in neutral (N). Certainly can't shift into 4LO on the fly like you can 4HI.
Old 12-24-2005, 02:35 AM
geneelder's Avatar
geneelder geneelder is offline
2005 Chevy TrailBlazer LS
You need to put your truck in neutral, then put the transfer case into neutral by holding the 4WD switch past 4LO until you see a red N, then release and it will go into 4LO. You may not even need to hold the 4WD switch until it goes into N, just put the tranny in N, then put the 4WD to 4LO.
2005 Trailblazer LS 4x4
Old 12-24-2005, 03:56 AM
Northwest Chapter
not here Other AWD
Thanks, that was what I was talking about. You need to put the tranny in N and then you can shift directly into 4LO, otherwise you need to put the Transfer case in N by holding the switch past 4Lo, when the red N lights, then you can release it and it will go into 4Lo.
Yea, I have done that before, just put it into 4LO for the heck of it, never needed it before.
Old 12-25-2005, 12:49 PM
chasmanz28's Avatar
2008 SAAB 9-7x
ok thanks guys
Old 12-25-2005, 12:53 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
If you don't do that, it will blink for 30 seconds and go back to the original setting. It's best to be moving at 1-3 MPH, but i don't know how you should do that while in neutral
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 01-11-2006, 01:27 PM
muddy tires's Avatar
muddy tires muddy tires is offline
Senior Member
2005 Chevy TrailBlazer LT EXT
I generally just let my TB roll slowly, put the transmission in neutral and flip the switch. The light flashes for a few seconds and then changes over. Never had to use it for real, but I've used it to pull the boat out of the lake. Take my foot off the brake and it just walks up the ramp.
Old 01-11-2006, 03:14 PM
2002BlkLTZ's Avatar
2002BlkLTZ 2002BlkLTZ is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
I do the same as the poster above me. Get it rolling 1-3mph, throw the tranny in Neutral, and then switch over. It drops right into 4LO. I used 4LO for pulling out some shrubs in the front yard once.
You may not post new threads
You may not post replies
Similar Threads
Got stuck in 4WD Low mikeb33 4x4 Drivetrain 7 02-04-2011 04:45 PM
misc electrical probs & low beam donaxemena General 3 10-18-2008 06:12 PM
low beam HIDs, high beam DRLs in 2004 TB lumina06 General 12 05-11-2008 11:47 AM
Can you run high and low beams together Nozz_69 General 4 08-24-2006 12:56 PM
Low Beams: NG by Design? Gearhed Exterior 7 07-25-2006 09:09 PM
