Tailgate won't open - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 12-01-2007, 11:43 PM
yrbam yrbam is offline
2002 GMC Envoy SLT
Cranberry Red Metallic 4.2L I6 4X4
Unhappy Tailgate won't open
The tailgate won't open on my 02 Envoy. It was working off n on if the key fob worked then it opened. Also using the unlock switch on door about 10 times it would finally open. Now neither work. When driving u can hear it switching like the door isn't shut all the way. How do I get it open?
Old 12-02-2007, 12:49 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Sounds almost like a bad ground to the LGM (lift gate module) which is inside the tailgate...so it will require you to open it.
I don't have the info on getting it opened right now; probably won't until Monday Sorry!
Hopefully someone else will be able to give you more info before then
-Mike
AKA PROVY
Rock On!
Old 12-02-2007, 04:43 PM
2002 GMC Envoy SLT
Thanks. That's what I was wondering if I have to get the gate open before anything can be done. I may never have it open hahahah. You would think there would be a manual latch in back for things like this or maybe even emergency exit.
Old 12-02-2007, 05:14 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
On the inside there should be a plug in a hole about 1.5" dia on the rear plastic panel down at the the bottom in the center where it bulges out a little, that covers the latch. You can pop out that plug and manually release the latch to get it open. Not sure how it works haven't had to do that!
Old 12-02-2007, 09:23 PM
2002 GMC Envoy SLT
Thanks, I was able to get the hatch open. By the time I did that it got dark and cold so I will save it for later when I get in the mood to mess with it. Now that I can get the door open and remove the panel what do I look for (Liftgate module) and how will I know if its bad ???
Old 12-02-2007, 09:54 PM
tblazed's Avatar
Does anything else in the liftgate work? Lights, wiper? Might start by checking the wiring from the top of the liftgate where it goes through a rubber boot. They occasionally break there. Two orange should have battery + voltage, black ground, Light Blue is the Class 2 serial data to the liftgate module, brown is park lamp supply to the license plate lights. Or might disconnect the battery and pull the boot out to unplug the harness in the roof and check continuity of each wire. And check all the liftgate module plug connections for problems or corrosion.
Similar Threads
Tailgate won't open cscarpine General 19 10-24-2015 05:50 PM
XUV tailgate problems Ben98gs General 10 05-31-2011 07:27 PM
02 Ltz Tailgate 69dart383 General 0 01-21-2008 04:20 PM
Old Orchard - Maine = Cape Cod The Black Pearl Everything Off-Topic 25 02-26-2007 10:49 PM
Door not wanting to open...? BPierce390 General 6 11-04-2006 11:46 PM
