MAF LOCATION (mass air flow sensor) - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-16-2007, 09:18 AM
Trail02Blazer Trail02Blazer is offline
2002 Chevy TrailBlazer LS
Hello can anyone tell me where the MAF Sensor is located on a 2002 Chevy Trailblazer? Do they even have a Mass air flow sensor? If not, what measures the amount of air passing through into the engine? Because I know that the PCM uses this information to control fuel delivery. thanks
Old 12-16-2007, 10:34 AM
blktbz's Avatar
blktbz blktbz is offline
TrailVoy Guru
Onyx Black 4.2L I6 4X4
As far as I know, there were no MAFs on '02 models. They were introduced a few years later.
Ex-TrailVoy'er, Current S10'er.
Old 12-16-2007, 10:39 AM
AbsoluteZero AbsoluteZero is offline
2003 GMC Envoy SLT
It doesn't have a MAF. The PCM "calculates" airflow using it's inputs to determine air density and flow.
Old 12-16-2007, 11:14 AM
turbomike's Avatar
turbomike turbomike is offline
2005 Buick Rainier
Black 5.3L V8 2WD
02's have the older style "Speed Density" type engine control system.
ADM CAI, UD Pulley, SW Exhaust, Bose Lux Amp
Old 12-16-2007, 01:12 PM
seawolf06's Avatar
seawolf06 seawolf06 is offline
2007 Chevy TrailBlazer LT
I can't believe GM was still using speed density in 02!!! I thought they started using MAF in 94, at least that's when they started using them in the Camaros.
When was it introduced to the Trailvoys?
Old 12-16-2007, 02:01 PM
pogbobo's Avatar
pogbobo pogbobo is offline
Senior Member
2006 Chevy TrailBlazer LS
I think some of the 05's and then all of the 06's to present
Old 12-16-2007, 04:36 PM
Warwagon Warwagon is offline
2007 Chevy TrailBlazer SS (3SS)
Summit White 6.0L LS2 V8 2WD
1985 Olds 3.8L with bank fire injectors used a MAF.
Old 12-16-2007, 09:37 PM
Thanks Guys
Thanks guys for all the help!
Old 12-17-2007, 08:32 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Well Im pretty sure the 02-05 I6 was the only engine to use SD from GM since the late 90s (except for the I4/I5 Coly engines that are the I6 minus 1 or 2 cylinders). I dont see why its a BAD thing, I think its actually better as its 1 less thing to fail and GM was still able to extract the power and mileage they wanted (did the mpg go up in late 05/06 when the revised I6 was introduced, no). HP/TQ did go up but the MAF has nothing to do with that, its the internal changes GM made that give the boost.
Old 12-17-2007, 08:35 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
Well that sux for us 02s
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
Similar Threads
Outside air temp sensor gone bad? anyone? impalajunkie General 24 04-15-2013 09:24 PM
head and cams design IceN OEM Issues 13 01-15-2009 02:55 AM
Outside Air Temp Sensor gclark63 General 3 12-27-2005 11:25 PM
cold air intakes thor Air Induction 138 12-07-2005 08:56 PM
Mass Air Flow Sensor 04chevyMN Air Induction 4 11-25-2005 07:55 AM
