05 Trailblazer Lights Dim - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-23-2008, 07:37 PM
roscocoop roscocoop is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I've been noticing that when I start my vehicle that the lights dim, or flicker for a few moments and that my voltage guage goes back and forth when the lights flicker. My dash lights and headlights do this. Any ideas on what could be causing this?? It only does it for a minute or two. Thanx
Old 01-23-2008, 07:49 PM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
2006 Chevy TrailBlazer LS
Is the vehicle under load when started? Like is the heat or defroster set to "on" before you start the truck?
Do you have an aftermarket stereo that sucks alot of juice that may be on at startup? It may take a moment for the electrical system to compensate for any of these things.
Just a thought.
Oh, and WELCOME!
Old 01-23-2008, 07:51 PM
Fishhunter911's Avatar
Fishhunter911 Fishhunter911 is offline
New Member
2007 GMC Yukon SLT
Onyx Black 5.3L V8 4X4
no worries, my 06 has done it since day one, I think most of them do. Come to think of it, my 02 did it as well.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 01-23-2008, 08:16 PM
SATBLS's Avatar
SATBLS SATBLS is offline
Graystone Metallic 4.2L I6 2WD
This is fairly common and really nothing to worry about. I started a thread when my '05 started doing the same thing, back in, well...'05. Anyway, I posted a link to the thread below. It has a bunch of people reporting the same problem as you, several methods/attempts to fix, diagnose, and isolate the problem (mostly unsuccessfully) and some theories on what could be causing it. I don't think we've got it figured it out, but at least this will let you know that you aren't alone with this, and it probably won't cause any significant issues.
http://forums.trailvoy.com/showthread.php?t=2214
2005 Trailblazer LS - SOLD
2009 Infiniti G37
2002 BMW 330Cic
Old 01-23-2008, 08:43 PM
smalltownrp830's Avatar
smalltownrp830 smalltownrp830 is offline
2002 Chevy TrailBlazer LS
Victory Red 4.2L I6 2WD
mine does it too...
Old 01-23-2008, 08:47 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Yeah, it's a design thing, we just don't know why they designed it that way.
Ray
Old 01-24-2008, 12:55 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
i believe its because 1st thing when turned on is....
The alternator DOES NOT start to pump out juice for a few seconds.. I dont know the time- but theres a delay from when the engine comes on to the alternator being commanded to start putting out.
Everything is working off the battery......
and
in 05 I think is when they put in the AIR pump.
It also runs when you 1st turn on the vehicle. that little pump draws some current. It gets worse if it has water in it (failing valve)- since it appears to draw more power.
eventually the little motor turns off and the alternator comes on. tuhs the dimming and lights getting bright.
thats what Ive picked up from here over time.
Old 01-24-2008, 01:33 PM
swartlkk's Avatar
swartlkk swartlkk is offline
2004 Chevy Tahoe Z71
63U - Sport Red 5.3L V8 4X4
My '04 Rainier does the same thing and has the air pump.
I tried most of the fixes suggested in other threads. Now that I installed a remote start that is all over and done with by the time I get behind the wheel.
Old 01-24-2008, 01:38 PM
Knightslugger's Avatar
Knightslugger Knightslugger is offline
2004 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 4X4
all trailvoys have an AIR pump.
mine does this during cold (and by cold i mean 20*F or less) all the time, maybe for 10 seconds at the most. It is the Air Pump that is drawing insane amounts of power (for a blower motor).
if you're driving around and you notice your lights dim as you let off the gas, the AIR Pump is probably activating, which is perfectly normal because it's trying to burn unused Hydrocarbons (gasoline) in the exhaust pipe before it gets to the catalytic converter. It's for emissions.
PCM4Less.com Tune (mild)
De-racked
quad-beam'd
Old 01-24-2008, 01:50 PM
DonWs05's Avatar
DonWs05 DonWs05 is offline
2005 Chevy TrailBlazer LT
Sand Beige Metallic 4.2L I6 2WD
Minor point but don't forget that if your lights are on WHILE YOU'RE CRANKING it will be normal for the lights to dim because of the current draw of the starter. Just thought I'd throw that in. I've read the other posts, haven't seen this issue in my 05 TB.
My other ride is a Syclone...
Don
Similar Threads
OEM Trailblazer, Envoy Electronic Visco Fan Clutches EuroPartsAmeric Basic Vendor GroupBuys 26 01-14-2012 03:54 AM
Lights Flicker or Dim jestockert General 12 06-11-2008 01:15 PM
2006 Trailblazer NHTSA Recall-FYI tb2006 OEM Issues 0 02-01-2008 11:40 PM
LED tail/brake lights afjfam Exterior 35 09-12-2007 12:02 AM
