OK To Drive In 3rd Gear All The Time? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-27-2008, 03:28 AM
Prey521's Avatar
Prey521 Prey521 is offline
Senior Member
2005 Chevy TrailBlazer LT
Hi guys, I was wondering...........I live in Upstate, NY where it's mountainous and often find myself dropping into 3rd gear on the highway. Is it OK to drive in 3rd gear all the time? Will it consume that much more gas? Bad for the engine? Thanks!
Old 01-27-2008, 08:54 AM
Rottie's Avatar
Rottie Rottie is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
It shouldn't hurt anything, but you will notice a drop in MPG. It's actually better to hold the transmission in direct drive (3rd) on hilly terrain than to have it frequently searching for the right gear. Frequent shifting causes heat and heat is a transmission's #1 enemy. However, if you do get on some flat roads for a while above 55 MPH or so I would suggest using OD for the MPG gains.
Old 01-27-2008, 10:32 AM
DrumMedic965's Avatar
DrumMedic965 DrumMedic965 is offline
2007 Chevy TrailBlazer LT
Being that you're transmission is searching all the time going up those hills, you might not lose too much fuel mileage by keeping it in 3rd all the time. Like Rottie said, on the highway I wouldn't drive on 3rd.
Drew
Old 01-27-2008, 10:48 AM
Jozuah's Avatar
Jozuah Jozuah is offline
Senior Member
2004 Chevy TrailBlazer LT
i live in northern utah, i had this same issue, so i bought a tune and the searching is gone, noew if you try and lag the truck it will still search for the gear, but its much better now if you just drive it....
Josh
there is no replacement for REAL LIFE experience!
2004 Trailblazer resonator removed
PCMFORLESS tuned
Old 01-27-2008, 10:52 AM
DucatiSS DucatiSS is offline
TrailVoy Guru
1969 Rambler Rogue
Camo Other 2WD
No problems. I use an old Silverado as my work truck and tow a 3500# trailer all day. I always leave it in 3rd. while towing. As others have said, a little less mileage due to increased RPM but no worries.
Gone to a better place
Old 01-27-2008, 03:32 PM
Prey521's Avatar
Senior Member
Cool, thx...I also have a Westers Tune and like to leave it in 3rd for the added OOOMPH!
Old 01-27-2008, 03:55 PM
blktbz's Avatar
blktbz blktbz is offline
TrailVoy Guru
2002 Chevy TrailBlazer LS
Onyx Black 4.2L I6 4X4
They found your TB?
Ex-TrailVoy'er, Current S10'er.
Old 01-28-2008, 02:13 AM
Prey521's Avatar
Senior Member
Originally Posted by blktbz View Post
They found your TB?
Ya, I updated the thread!
Old 01-28-2008, 08:40 AM
tcarricato tcarricato is offline
I drive in 3rd alot too mostly on hilly roads, but i go back to OD when i hit the highway. Staying in 3rd shouldn't hurt anything.
[SIZE="1"][/SIZE][I][COLOR="Blue"]It's like you know :confused:[/COLOR][/I]
Old 01-28-2008, 03:28 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
yup. manual says its ok to drive in 3rd.
BUT mileage will decrease.
Similar Threads
OEM Navigation: More Info Than You Could Possibly Want to Know Murp4099 Audio and Electronics 395 08-08-2016 12:12 AM
07 TB rear hatch wont lock all the time MikeInMobileAL Exterior 15 04-05-2012 10:46 PM
HOW TO install a cam ? dv_tbss06 Engine Tunes/Mods 15 08-29-2011 08:20 PM
