Emergency Brake Adjustment? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 01-04-2006, 12:37 AM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Has anyone noticed that their e-brake doesn't hold so well at times? Is there an adjustment or something? When I drove home to PA the driveway at home has a good slope on it, and I set the e-brake like I always to (I like to keep the weight of the car off the parking pins in the transmission, even on flat ground) and I notice the truck about lurched forward until the parking pins in the tranny caught...which is exactly what I didn't want to happen. It seems to happen more when the truck is facing downhill than when facing uphill. Does anyone have any input? Thanks...
http://www.signal46.com/images/c138s.jpg
In memory of PFC Dawn Tillman, County 138
Old 01-04-2006, 01:14 AM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
My TB moves forward/backward about 2 inches before locking. It doesn't look like the handbrake does anything
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 01-04-2006, 01:59 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
I have had to readjust my handbrake a few times, they are almost worthless on the TBs. There is an auto adjustment procedure along these lines, pull the e-brake boot, push the lever on the front down 3x, and then cycle the e-brake 3x to readjust. It helped me a little, but unless I am on a steep grade I dont bother to set it anymore.
Old 01-04-2006, 10:54 AM
OurZoo's Avatar
OurZoo OurZoo is offline
Black & Stl Blue Metallic AWD
Mine lurches forward or backward about 2 inches as well. I always set the handbrake even at home in the garage. It's a habit!
'07 Grand Cherokee SRT8 Diablo Tuned/Bwoody CAI/BORLA S Exhaust/Spacers/180 Tstat
'07 Charger SRT8Diablo Tuned/AFE II CAI/BORLA Exhaust/180 Tstat
Old 01-04-2006, 03:47 PM
APDMC6008's Avatar
Yeah same here. I'd bet the farm that mine has its brake set right now in the garage and that's a completely level surface. My first car was a 5-speed, and of course I always set it on that thing, and when I got my first AT, I never set it. I figure I just set it to keep the weight off the parking pins in the transmission -it doesn't hurt anything to set it. I'll try that adjustment thing and see what happens.
Old 01-04-2006, 04:39 PM
itchyfishnv's Avatar
itchyfishnv itchyfishnv is offline
Senior Member
2003 Chevy TrailBlazer LTZ
Black/Pewter 2 Tone 4.2L I6 4X4
mine didnt work well either until i changed my brakes, and now it works as it should, doesnt roll in neutral on any hill.
Old 01-04-2006, 08:38 PM
APDMC6008's Avatar
Gah! Don't say that!!! Of course, I'm at 67000 mi and still have (to my knowledge) factory pads and rotors on the truck... I bought it with 22K on it, but I doubt they would change them that soon, but who knows!! I'm probably due for new brakes. Guess I'll examine that route.
Old 01-04-2006, 08:43 PM
Senior Member
im not saying dont replace them if they dont need it, you can adjust it as they wear, but ull have re-adjust it when you put meatier pads and rotors on.
Old 01-04-2006, 08:56 PM
zamar's Avatar
zamar zamar is offline
Senior Member
2002 Chevy TrailBlazer LTZ
Victory Red 4.2L I6 2WD
FWIW the parking brake does not use the rear pads. There is a set of shoes behind the rotor. So the rear brake is a disc (normal braking) and a drum (parkin brake).
At least on my '02.
2002 LTZ - 2wd, 142k miles
Old 01-05-2006, 12:22 AM
03slt_soccal's Avatar
03slt_soccal 03slt_soccal is offline
2003 GMC Envoy SLT
there is an adjustment on the parking brake shoes you have to remove the rotor and caliper then you will see the star adjuster crank it up a little
2003 Envoy SLT summit white
1997 chevy 1500 prerunner
2004 v-star classic 1100
You may not post new threads
You may not post replies
Similar Threads
emergency brake question/problem pinbot Brakes 12 09-13-2010 05:16 PM
Parking brake needs adjustment after brake job MrBigStuff Brakes 4 09-10-2008 06:37 AM
need help with parking brake adjustment nymanny21 Everything Off-Topic 1 05-02-2008 03:25 PM
Rear Pads and Rotors ma2169 Brakes 4 02-29-2008 10:28 PM
Emergency brake robertgee General 2 11-07-2007 07:09 AM
