Power Draw - Cold Start - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-30-2008, 09:27 AM
jmedlin6's Avatar
jmedlin6 jmedlin6 is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Is anyone else having this problem? First off I want to say that I do have a new optima battery, 150 amp alternator (Bearings went bad in my old one), and proper serpentine belt. The problem is (and it was happening before I got the new alternator) when I start my car in the morning and its about 20F it seems to take about 10 - 15 seconds for my charging system to read normal around 14. It would hang around 12 then all of a sudden shoot up. Is this just another wonderful design flaw. It's been doing this all winter but just decided to see if anyone else is having the problem. Once its started it usually doesn't do it the rest of the day. Like I said it only does it when its cold.
Old 01-30-2008, 11:11 AM
emti309's Avatar
emti309 emti309 is offline
2002 Olds Bravada
Indigo Blue Metallic 4.2L I6 AWD
Mine does it too. I have been having this issue all winter. Figured just needed a new battery but maybe just the way the truck is.
Old 01-30-2008, 11:33 AM
gdewit79's Avatar
gdewit79 gdewit79 is offline
Senior Member
2004 Chevy TrailBlazer LT
Light Tarnished Silver 4.2L I6 4X4
Mine does this too! And until everything kicks in where it should, it seems like the truck is going to stall, and I am afraid of turning anything on, such as stereo, heating fan, heated seats, etc.
Old 01-30-2008, 11:47 AM
ilikemy3s's Avatar
ilikemy3s ilikemy3s is offline
2004 GMC Envoy SLT XL
Summit White 4.2L I6 4X4
I would check your battery cables and or at least the connections. Like anythings else over time, the copper in the cables can breakdown and cause problems like that ..
Old 01-30-2008, 11:51 AM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
This issue has been discussed several times before, both here and on another forum I use to monitor. Seems just about every TB/Envoy seems to do this, at least the ones with an I6 that use the 145a alternator. Most people only really notice that the lights suddenly brighten after a few seconds and don't watch the gages to realize its the voltage level doesn't come up to normal right away in really cold temps. There's just something in the voltage regulation circuitry of these trucks thats slow to come up to normal in cold weather. From what I've seen and read, it appears to be a normal phenomena for our trucks.
Old 01-30-2008, 01:12 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
I agree.
from previous discussions. this is more apparent on the vehicles with the AIR PUM
it appears that the alternator on the TV do not turn on immideately. It takes a few seconds for them to start putting out juice.
This appears to be more prevalent in cold weather areas and those with the AIR PUMP.
since the alternator is not yet active- the AIR pump is drawing power from the battery- which is already in a degraded mode simply because its really cold. when the alternator comes on- you see that spike- and the AIR pump had also shut off.
Old 01-30-2008, 11:56 PM
jmedlin6's Avatar
4.2L I6 4X4
New Issue
Okay, so now I think something is wrong w/ the alternator. My Headlamps flicker constantly and my guague fluctuates and doesn't stop like it usually does w/ the AIR Pump. I even let my TB sit for a few mins prior to driving. Any ideas. Do you think it is a bad alternator that I just installed?
Old 02-13-2008, 02:09 PM
jmedlin6's Avatar
4.2L I6 4X4
Alternator
Well I finally replaced the net alternator that I put in. It turned out to be faulty.
Similar Threads
Brake fluid flush with motive power bleeder iznit OEM Issues 12 05-08-2012 08:24 PM
4x4 won't engage when cold masterninja2357 4x4 Drivetrain 8 07-09-2008 10:14 PM
Power Steering Fluid Cooler? jcv22jr OEM Issues 0 01-03-2008 03:03 PM
TB won't start... TuBlaz General 22 08-18-2007 11:10 PM
