Rear Wiper Not Working - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-30-2008, 09:10 PM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Still going through everything, but looking to see if anyone has had their rear wiper up and quit on them. The only thing I can think of is yesterday I put the Battery on a 2A charge for a bit. Shouldn't be the cause of the problem but it hasn't worked since yesterday either.
Thoughts?
Old 01-30-2008, 09:22 PM
STREETTEC's Avatar
STREETTEC STREETTEC is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Thoughts?
Too funny! Mine just went out 2 days ago! I haven't had a chance to look into it... but I am thinking fuse... same day my radio decided to reset the time (but stations and settings stayed the same) . I haven't done anything electrically new to my car so I have no idea why it would be doing this... Maybe moisture?? It has been raining a lot lately.
Old 01-30-2008, 09:26 PM
Senior Member
Well its been very cold here. I checked all the fuses then swaped the rear wiper relay with the fog light relay and it works. But so do the fog lights. Its either the cold or an electrical gremlin.
In any case, problem solved, for now....
Old 01-30-2008, 09:29 PM
Senior Member
I would say start with the fuses. Maybe yours is an easy fix too
Old 01-30-2008, 10:38 PM
tunnerguy tunnerguy is offline
2007 Chevy TrailBlazer LS
hey guy, just thought i'd add my 2 cents - seeing as you and i share the same type of weather i'd thought i'd let you know about how everytime i wash my truck and go out in the cold my rear wiper won't work - it freezes up in fact. when it warms up - no problem. my buddy at a local dealer told me that it is designed not to work if there is any type of resistance. so that the arm won't break. just thought i'd share a story.
Old 01-31-2008, 07:20 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
could be frozen, could also be stuck. By stuck, I mean in the plastic perch.
Ray
Old 02-01-2008, 02:54 AM
dex dex is offline
New Member
Thoughts?
hi, most likely when u charged ur battery u reset ur rear gate madule (crappy electrical engineering) anyhow it happened when i replaced my battery, remote not working and rear wiper not working, any how way i fixed it was to unhook the battery and let it sit over night then reattach and let the engine run or drive for half an hour, don;t turn on ur rear wiper or use ur remote during this half hour. it should work after that.
Old 02-06-2008, 05:44 PM
STREETTEC's Avatar
Black 4.2L I6 2WD
Ok... so yesterday I checked the fuses with a voltmeter and they are "fine"... Disconnected the battery for awhile... connected the battery and waited awhile and tried my rear windshield wiper... still didn't work... the windshield wiper fluid sprayer works though... so, could it be the rear windshield wiper motor or the switch?
Any help or suggestions would be awesome!!
Old 04-15-2011, 10:31 PM
shaun4282's Avatar
shaun4282 shaun4282 is offline
2004 Chevy TrailBlazer LT
Onyx Black 4.2L I6 4X4
saw how old this thread was, mine stopped working as well, spent 40 mins looking at the wires in the rubber boot on the hinge.....all looked good...did anyone ever figure out what the problem was?
Old 04-15-2011, 10:36 PM
Greying Greying is offline
2009 Chevy TrailBlazer LS
Misty Green 4.2L I6 4X4
rear wiper
Thoughts?
The rear wiper went on my 2009 this winter at 58000km. It was the motor according to the dealer but then again I never saw it and it was replaced under the bumper to bumper. I really suspect it was only the switch because they changed that to.
G.
Similar Threads
Bad rear wiper switch? Outback_Jon Interior 11 01-11-2015 07:36 PM
Rear Wiper Not 100% there... Murp4099 General 11 09-17-2007 11:32 PM
07 Rear Wiper Rest Michblaze02 Exterior 12 06-19-2007 09:42 PM
FOB / REAR WIPER not working- Is it the lift gate? OSCARITO OEM Issues 13 05-25-2007 11:28 AM
rear windshield wiper Project_P Exterior 1 10-27-2006 05:00 PM
