Troubleshooting P0410 Code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-23-2008, 10:17 AM
barley30 barley30 is offline
2004 Chevy TrailBlazer LS
Black Granite Metallic 4.2L I6 4X4
First time poster here. I recently purchased a 2004 TB LS, 4.2 L Vortec and 49K on it. About 1 week after I had changed the OEM air filter my Service engine light came on so I took it to AutoZone to read the code. It came back with the following message:
P0410
Definition
Secondary Air Injection System fault
Explanation
The air injection system is monitored for faults
Probable Causes
1) Circuit relay defective or fuse open
2) Check connector and wiring
3) AIR pump defective or hoses blocked
I have re checked the stock air box to see if I accidentally left something off, but I see nothing. This problem might be coincidence.
Has anyone experienced this problem before and is there some easy checks that I can do before I take it in for repair? Where is the Air Induction pump and it's hoses/connectors?
Old 02-25-2008, 11:48 PM
Thumbs up
UPDATE:
After reviewing several other posts regarding this same problem, I was able to resolve the situation.
http://forums.trailvoy.com/search.php?searchid=1260519
It ended up being the Check Valve that is mounted n the passenger side of the engine directly below the intake hose. Part # 12575655.
I shopped around the local Dealers and found on that was willing to sell it well below list ($90 plus tax). You can find this part online for a little less but I could not wait. It took all of 10 minutes to install and I reused the original gasket along with Hi temp gasket sealant.
After installation I went to Auto Zone to have the SES light cleared but they told me they can no longer clear the codes due to a letter they recieved from the Government threatening a fine due to emissions? Has anyone else heard that?
Any shortcuts that I can try (i.e batter disconnect, ignition tricks)??
Old 02-28-2008, 02:00 PM
dsiegelson dsiegelson is offline
Liquid Silver Metallic 4.2L I6 4X4
to clear the code you can purchase your own scan tool, several peorple on this site including me have bought the ones made by actron, Autozone sells them.
Old 02-28-2008, 02:42 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Rent a code reader from Autozone.
they allow yout to rent- it... you leave a deposit- equal to its value- I use my credit card.
I walk out read or clean code, and return it. they remove the charge on my card....
this is one I rented from Autozone about 1 hr after I finished replacing my thermostat.
Old 02-29-2008, 11:53 AM
georgenola georgenola is offline
2005 GMC Envoy SLE
Fire Red 4.2L I6 2WD
Code Reader from Autozone
Do they give you the code book with the scanner. My `05 Envoy is constantly showing a check engine light that the bozos at the dealership can't trace. I've narrowed it down to using ethanol gas.
Old 02-29-2008, 11:56 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Did they tell you / document the code # (what is it)?
Was it a GM dealer?
-Mike
AKA PROVY
Rock On!
Old 02-29-2008, 12:04 PM
2005 GMC Envoy SLE
Yes, GM dealer who sold the car. I'm an old guy in a suit, so they gave me some crap aout cleaning the injectors. $500 later, the light comes right back on as I leave the lot. They then blame the gas cap, as in "perhaps you don't have it screwed on tight". Oddly enough, I know how to put on a gas cap, and that isn't it. So, they just clear the code again and tell me to see if it comes back on. After a couple of visits like this, I realize that they don't have a clue.
Old 02-29-2008, 01:10 PM
PROSPHOTO's Avatar
Did they give you the code #; is it on your receipt?
Also, Please fill out all of the vehicle info in your user CP (edit profile) so that everyone can see what vehicle you're driving/refering to when the read your posts. Also, include your location; this may aid in possible assistance regarding laws and obligations protecting repair shop customers
-Mike
AKA PROVY
Rock On!
Old 02-29-2008, 10:35 PM
UPDATE:
After driving the car for the next few days, the SES light went away on it's own. I guess that proves that I actually fixed the problem!!!!
After reading a lot of tyhe comments in this forum, I do need to purchase a code reader.
Old 10-02-2009, 08:54 PM
Juanc1987 Juanc1987 is offline
2004 GMC Envoy SLE
just got this problem.
just recently fixed my voy from codes P2101 P0113 but just today i scanned my truck and got codes P0410 and P0141 i still cant figure it out i know meaby P0141 is the sensor by the cat but P0410 i dont know.
Similar Threads
Build Sheet lucaswhunter General 29 05-27-2012 02:42 PM
Stupid P0410 code! Audiojunky OEM Issues 24 05-07-2011 03:04 PM
Stupid P0410 code! Audiojunky OEM Issues 0 06-16-2008 02:26 PM
SAI (P0410) Code RozmerJJ OEM Issues 0 03-16-2008 04:22 PM
P0410 code exvetteowner Air Induction 4 03-16-2008 01:02 PM
