Locating Transfer Case Module - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-07-2008, 02:37 PM
sinvids sinvids is offline
2002 GMC Envoy SLT
Hi All,
I've had the diagnostics run on my '02 Envoy Slt and low and behold my transfer case module is faulty. My question is I purchased a new one on Ebay for $60.00 and was wondering where the transfer case module is located and can I change it myself? I know the reprogramming has to be done at the stealership but can I change the module before I get there or should I let them do the switch? Any help would be appreciated!
Natalka
Old 03-07-2008, 03:49 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
If you remove the cover on the left side of the instrument panel, you will see the module. You will need to remove the lower insulator panel to remove the module...you should be able to replace it yourself; it's fairly easy
However, I don't know what's going to happen when you try driving the vehicle before programming the module
Suggestion...make the appointment to program the module, bring the truck to the dealer, replace the module in their parking lot. When the tech comes out to get the car, let him know you just replaced the module and he can download the vehicle information in the parking lot. Once the info is in his Tech 2, he has to download the appropriate software from the computer terminal in the building, then upload it into your truck
-Mike
AKA PROVY
Rock On!
Old 03-07-2008, 04:48 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
You are talking about the switch, I think sinvids needs to replace the TCCM encoder motor...
sinvids, is it just the switch or the the transfer case encoder motor?
Old 03-07-2008, 04:58 PM
PROSPHOTO's Avatar
The TCCM (transfer case control module) is under the dash...the module is mounted to the instrument panel "mag beam" () via a plastic mounting bracket. It has 3 electrical connectors in it.
The transfer case encoder motor (if interested) is bolted to the transfer case.
There are multiple components in the system; the main electrical components are the Transfer Case Shift Control Module (uses the Vin specific info for calculations that are required for the different calibrations used based on axle ratio, transmission, tire size, and engine), the Transfer Case Motor / Encoder, and the Transfer Case Shift Control Switch.
-Mike
AKA PROVY
Rock On!
Old 03-07-2008, 05:16 PM
2002 GMC Envoy SLT
I think you might be confused because I paid $60.00 (great deal on Ebay, here they cost $512.00 plus tax at the dealership!). My 4x4 isn't working and the dealer told me it was the TCCM that was the problem. I found almost everyone that has an Envoy or Trailblazer has this problem eventually.Either way, I will look under the dash right now to try to find the exact part as what I got today. Hopefully it works and the whole thing will cost me less than $200.00 to fix! (I live in Montreal where it's snowing like crazy this year!)
Old 03-07-2008, 08:52 PM
JMal's Avatar
JMal JMal is offline
Senior Member
2002 Chevy TrailBlazer LT
Black TrailBandit 4.2L I6 4X4
$186 + shipping from parts4chevys.com
Sign up now -
Old 03-08-2008, 03:39 PM
2002 GMC Envoy SLT
$512.00 Montreal, Canada dealership!
Old 03-08-2008, 03:42 PM
2002 GMC Envoy SLT
I couldn't seem to locate it. I unscrewed the two pieces beside and under the steering wheel, and did not find the part anywhere. Can anyone be more specific in it's placing? Thanks!
Old 03-08-2008, 05:13 PM
PROSPHOTO's Avatar
If you open up the left (drivers) side instrument panel cover (that you see with the door open), you can see the three connectors. This picture shows the module if you were looking at it from the cowl:
-Mike
AKA PROVY
Rock On!
Old 03-09-2008, 10:37 AM
Chacal Chacal is offline
2003 Chevy TrailBlazer LS
Sandstone Metallic 4.2L I6 4X4
Sinvids:
Check for local scrapyards. In St-Hubert, there's a place called "Pat". You can get it for 175$ and 3 months warranty.
Similar Threads
Why no 4 by 4 switch? Vader AWD Drivetrain 25 03-02-2010 10:00 PM
Transfer Case Fluid Change (Automatic Transfer Case Only) Trefilov22 4x4 Drivetrain 8 01-11-2010 05:24 PM
TB 06 4WD, Transfer Case Damage alialali 4x4 Drivetrain 3 10-11-2007 10:42 AM
Shudder, Rocking Motion, Binding, Feels Like Vehicle is Stuck in 4WD mickdigler 02-09 Vortec 4.2L I-6 Engine and Drivetrain 9 10-02-2006 11:38 AM
Transfer Case Is Bad trailblazer02 4x4 Drivetrain 1 05-30-2006 11:36 PM
