Whining noise at start-up - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-10-2008, 01:13 AM
akcrx akcrx is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
I get a whining noise from my 04 trailblazer for about 30-50 seconds after start up. Sort of sounds like a Airplane engine. I have been looking through the threads and noticed that some issue look like the fan clutch assembly. I also notice people complain about a whine which originates from the power steering pump. Is there any way to confirm which one is the culprit? It only happens during start-up. Also I noticed some people talk about changing to efans. What exactly is that and how much does a kit cost?
Old 03-10-2008, 10:38 AM
SCs_5th_Gen SCs_5th_Gen is offline
2005 GMC Envoy SLE
Not sure we can electric yet, there is a company doing a test but I think they are pretty expensive.
It sounds to me like the fan clutch. My 05 Envoy sometimes does that. If I start it then drive away almost immediately then it happens for about 10 seconds.
Old 03-14-2008, 10:08 AM
Jozuah's Avatar
Jozuah Jozuah is offline
Senior Member
is the whine always followed by a THUMP or more spelled like it actually sounds a FFFWOOOMP .. if so thats totally normal its your AIR system pre charging your catalytic converter with fresh oxygen rich air.
as far as the E-fans they are in production and are availible through PCM4LESS at this link http://forums.trailvoy.com/forumdisplay.php?f=116
there is no replacement for REAL LIFE experience!
2004 Trailblazer resonator removed
PCMFORLESS tuned
Old 03-14-2008, 10:15 AM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Sounds like it MIGHT be the fan clutch going bad. How many miles on your TB?
Mine went bad at about 60K
Old 03-14-2008, 01:27 PM
bullethole's Avatar
bullethole bullethole is offline
Senior Member
Sandstone Metallic 4.2L I6 4X4
Some fan clutch lockup on startup is normal. If it continues after 30-40 seconds then the fan clutch is starting to fail. It really depends on the outside temp also.
Troubleshooting rule #1 : Check the simplest and least expensive things FIRST!
Old 03-14-2008, 01:34 PM
NickDanger's Avatar
NickDanger NickDanger is offline
2007 Chevy TrailBlazer LT
On occasion, I have had a whining sound upon start up also, it was coming from the seat next to me and after taking the whine out to dinner it was a lot quieter afterwards. Forgive me for that one....
Old 03-14-2008, 01:38 PM
petevw's Avatar
Have any cheese with that whine?
Old 11-01-2009, 03:57 PM
technosapien technosapien is offline
2004 GMC Envoy SLE
Dark Green Metallic 4.2L I6 2WD
OK, I have to add in a question here. I have the exact issue. A whining noise very like a jet engine for about 30-45 sec on a cold start. If I have been driving for longer than a few minutes recently, stopped (ie. to go shopping) and come back in a short time, this doesn't happen, only on cold start. Clutch fan recently replaced... any other thoughts?
Thank you
- A
--- edit:
Leave it to me to add to a 1.5 year old post. If I should start a new thread, let me know. So far I've found: Idler Pulley and Power Steering pump may also be the culprits....
Old 11-01-2009, 04:01 PM
the roadie's Avatar
It's normal behavior for the newer design fan clutches.
http://forums.trailvoy.com/showthread.php?t=19604
Old 11-01-2009, 04:14 PM
2004 GMC Envoy SLE
Oh... interesting. So the noise led me to the shop, where they replaced the clutch fan, with a part that will continue to make noise.
Thanks for the info!
Similar Threads
Another whining noise Since76 OEM Issues 3 05-31-2008 10:47 PM
New noise at start up coolcloo1019 OEM Issues 5 05-21-2008 12:40 PM
Whining Noise when Radio is On - Sometimes PhillyEnvoy Audio and Electronics 4 06-05-2007 04:11 PM
crackling noise on cold start 03tb General 34 02-06-2007 09:57 PM
05 Envoy whining noise Got Rice Galant 02-09 Vortec 4.2L I-6 Engine and Drivetrain 2 10-28-2006 03:50 PM
