How do you remove the sun visors. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 03-24-2008, 04:45 AM
blazinlow89 blazinlow89 is offline
Senior Member
2004 Chevy TrailBlazer LS
I recently got a set of flip down monitors and i need to get the headliner down. Im not sure if the visors are in the way, but i will need to remove them eventually to install a set of sun visor monitors. TIA for any help.
Old 08-14-2008, 08:44 PM
ayannauriel's Avatar
ayannauriel ayannauriel is offline
2003 GMC Envoy SLE
I removed mine to recover them, and getting them off was really simple, just took a paperclip, door panel tool and a little muscle.
flip them down and move them parallel to the door window. Then straighten out a paper clip and stick it in that little access hole on the outside of the pivot arm. I used pliers to hold the paper clip because my hands kept slipping. Then, as you push the paperclip into the hole, move the visor so it's parallel to the windshield. The inner part that pivots should recess into the bezel, and the paper clip should move more into the hole. If it doesn't work at first, just keep trying by resetting and starting from the beginning. It took me a few times before I got the arm to recess into the bezel. Then take the door panel tool (you can remove the paperclip) and go around the sides popping the plastic away from the headliner. It was pretty difficult and felt like I was going to snap it off. It took about three points of using the tool to pry it off before I got it off. Turns out because there are three snap points on the inside that holds it together. They are triangle point positions if that helps give you an idea where to pry. You can also apply pressure and rock it back and forth while pulling (something I could not accomplish) instead of using the tool.
The only problem I have is getting the visors back ON So hopefully I'll either figure it out, or just take it to a shop and have them pop them back in for me. I can't find any tips on the site here.
Old 08-14-2008, 08:58 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
AMEN! Talk about a true pita....i was so f'n pissed off when I put mine back in that I said F taking pics...and that was just one
Basically the 3 tabs don't go where they look like they they should, they go into the recessed grooves up in the retainer....i had to take the visor and the retainer out to "practice" lining them up
Old 08-14-2008, 09:45 PM
2003 GMC Envoy SLE
YAY!!!!! THANK YOU! I never would have gotten them in without that tip. They don't seem to line up quite right, but its ok, I can get them clipped in when they're flipped up, and I live in the land of no sun so I rarely use them anyway.
Old 07-21-2009, 12:25 PM
jarret777's Avatar
jarret777 jarret777 is offline
2003 GMC Envoy SLT
Dark Gray Metallic 4.2L I6 2WD
question...
Can I pull the headliner down in the front, put the sunvisor into place and THEN put up the headliner... basically, I know that the sunvisor clip next to the rear view mirror that screws into the metal also helps keep the headliner up... does the swivel part of the sunvisor also do the same or does it just secure to the headliner?
Old 08-07-2009, 01:02 PM
TBLT03 TBLT03 is offline
2003 Chevy TrailBlazer LT
Sun visor removal
On my 05 TB , I just took out the 3 hex head screws and unplugged the light from inside the headliner. The other screw holding the other small part that the visor clips into will hold the rest of the head liner.
TBLT
03 Trailblazer Lt 4x4
05 Trailblazer Lt 4x4& 03 Olds Bravada AWD
Old 11-02-2009, 04:50 PM
EnvoySLE02's Avatar
EnvoySLE02 EnvoySLE02 is offline
2002 GMC Envoy SLE
Black 4.2L I6 4X4
The pivot/swivel part attaches to the sheet metal. I had to drop the hedliner corner down at the driver side yesterday. The process was relativly painless, thanks to comments above. Putting it back was not hard (I never took the visor off of the headliner). Basically, the pivot has a tab (not shown in picture) that needs to go in the key or groove in the sheet metal (right), then you turn and push up on the visor pivot until it snaps in place. It worked on the second trial. Hope the pictures below help.
Click image for larger version
ID:	7622   Click image for larger version
"To be brave, you must first be afraid. For true courage lies in overcoming fear, not in its absence" ... Blue Power Ranger.
Old 02-16-2010, 09:03 AM
aalmans aalmans is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 AWD
Crap, well i joined the club here.
When i bought my trailblazer i found out that the mirror of the passenger visor was removed by a previous owner. I got a replacement and removed the old one succesfully as described here.
The problem was getting the new one back in!!!! What a real PITA indeed!!!
Finally i was succesfull replacing it but only after some other tips i found. Here it is for others daring the same thing!
1) You first need to remove the windshield trim piece that goes from the dash to the headliner.
2) Next remove front assist handle from headliner. This is kind of tricky. Have a screwdriver handy and pop plastic covers up.n They are attached on the sides. Take handle and push towards the rear of the vehicle and stick screwdriver in hole and pry hold tab up. The front comes out similar.(Remove back of handle first)
3) Next recline seat and pop center trim back from it's clips.
4) Open and rotate sunshaded parallel to side window.
5) Insert a small tool into hole @ arm of the visor.
6) Push upwards on tool while rotating towards windshied. The pivot arm will appear to be recessed into the bezel now.
7) Push outward and pull down firmly. The sunshade and headliner should be seperated from the roof structure.
8) Now pull down the headliner and rock the visor up and down and the black clip should pop off above the headliner.
9) If you have lighted visors pull the wires away from the headliner and unplug.
INSTALLATION ::
1) Plug in visor.
2) Position wire into slot on visor.
3) Position visor into hole and place retainer clip between headliner and roof structure.(You will need an extra hand with this step) (Oh Yeh, The retainer clip is a real patience tester. There are (3) slots that it fits into on arm. Not to be confused with the wire hold down tab.)
4) Make sure visor is parallel with windshield and push up into hole. Continue upward pressure while turning visor towards side window. As you turned it the bezel should have become flush now.
5) Return all trim pieces to their spots.
Now my oldest daughter can put make-up on with mirror and light! Thanks to all that helped in this post!
Old 02-26-2010, 06:56 AM
bearhunter's Avatar
bearhunter bearhunter is offline
2005 Chevy TrailBlazer LS
My 2005 trailblazer is different. Just 3 screws and the sun visors come off. I recently purchased a set of sun visors that have the lighted, covered mirrors. They bolt right in place of my non lighted sun visors. I have asked this on another thread but haven't gotten an answer. Is the wiring harness there where all I have to do is plug them in, or do I have to cut and splice to hook up power to them? Thanks for any help you can give me.
Old 02-26-2010, 07:23 PM
Silver Trooper's Avatar
Silver Trooper Silver Trooper is offline
2002 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
First, have a beer (trust me on this one, and it will be the first of many). Then take the visor and align the slots. Have another beer. Push the visor up into the slots as far as you can, but use the proper slots...not the ones that it LOOKS like it would fit into. Have another beer. Push the complete assembly up into the hole with the visor parallel to the side window (or was it the windshield?) and start to push and twist towards the opposite side. Take a breather and have another beer because the first try was a dismal failure and for the life of me I cannot figure out how this f&*(ing thing is supposed to fit. If you repeat this process several times, you eventually get the right combo of pushing up and twisting forward that will get the visor started and then lock. Or you can sober up and take it to the dealer instead of shooting up the neighborhood in frustration!
Similar Threads
HOW TO install a cam ? dv_tbss06 Engine Tunes/Mods 15 08-29-2011 07:20 PM
WI Dealer giving me the BS on OCI? Knightslugger General 48 10-10-2009 11:12 AM
remote start - truck shutting off after a few seconds TheWraith Audio and Electronics 21 10-21-2007 10:03 AM
GMs Future Fleet by Fleet.. We all knew it was going to happen Chris Foresta Latest GM News 5 08-03-2007 10:41 AM
The adventures of glue and his power steering pump ieatglue 02-09 Vortec 4.2L I-6 Engine and Drivetrain 25 12-06-2006 09:22 PM
