whine during accelerating - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-30-2008, 04:47 PM
BlazinTrails BlazinTrails is offline
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
I have a whining noise during accelerating on my 2003 TB EXT. You can only hear it while pushing on the gas, mainly on the highway or at higher speeds. It sounds like it is coming from the rear end, any ideas? It does't happen just when turning ... it happens when you push the gas at any time. I don't remember hearing the noise when I purchased the vehicle about 2-1/2 years ago. Could it be tires? I just dropped a load of money on it for a tune up, tranny oil change and new front wheel bearings (they were noisy when turning). Now that all that is done I still have that annoying whine going down the highway. It is not noticeable in town, only on the highway. Thanks!
Old 03-30-2008, 11:05 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
How many miles? Have you changed the dif. oil? Have you checked the u-joints? Are the tires new or been on for a while?
Robert
Old 04-01-2008, 01:10 AM
Wake's Avatar
Wake Wake is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Start with changing the diff fluid, costs about $20 if you do it yourself... I had the same issue because I think the shop that swapped out my carrier didn't put synthetic back in, it started whining within about 100 miles...
I swapped out the fluid and added the GM limited slip additive and no more noise...
Old 04-01-2008, 12:35 PM
andrewmoore13 andrewmoore13 is offline
2002 GMC Yukon Denali
Summit White Other AWD
do you have an aftermarket stereo? could be alternator whine.
Old 04-01-2008, 12:51 PM
michiganTB's Avatar
michiganTB michiganTB is offline
2005 Chevy TrailBlazer LS
i doubt that is is the alrternator because it only happens when accelerating and if the alt then the noise would occur to some extent at idle. i ahd a whine noise a while back and it ended up being the idler pulley, but the tensioner pulley has also been a culprit for other people. i didnt want to suggest those though because you said it is coming from the rear end. either way if you cant figure it out it is at least something to check into. there are many articles or posts regarding the pulley noises.
08 IMPALA my gf crashed my trailblazer and i couldnt afford a new one
Old 04-01-2008, 03:05 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
it could be the alternator. I fix my alternator and that solved my problem!
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
Similar Threads
Finally fixed my engine whine! Audiojunky OEM Issues 240 11-07-2016 12:07 PM
Whine while accelerating in first gear MYBLK05LT Transmission Mods 6 03-04-2008 02:55 AM
HELP! Strange whine.. DB13 OEM Issues 4 12-30-2007 02:44 PM
Another TB whine thread MidwestSpecial OEM Issues 8 09-07-2007 05:46 PM
Engine Whine at WOT BLK06TBSS OEM Issues 4 11-09-2006 12:25 AM
