Replacing Starter - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 03-31-2008, 06:57 PM
brikon brikon is offline
2004 GMC Envoy SLE XL
Sand Beige Metallic 5.3L V8 4X4
Replacing Starter
I have a no start problem on my 04 Envoy XL V8. I have been troubleshooting and believe the problem in the starter. Battery is new and tested, the starter relay clicks; but, no click for starter solenoid.
Has anyone replaced a starter on the V8? I have AllData and the procedure calls out removing the catalytic converter, which is pretty involved. If anyone has done the starter replacement and has some tips that would be great.
I am new to the forum and if someone needs some info from AllData let me know.
Thanks,
Brian
Old 04-02-2008, 10:27 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Thanks,
Brian
Sorry nobody has an answer for you - I don't remember hearing about too many people replacing their starters here.
I've been here for a couple of years or so, and I've heard of many ignition switches being replaced, just not very many starters and the few that were replaced were done by the dealership under warrranty.
Old 04-03-2008, 07:54 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Thanks,
Brian
Brian, your words "no start problem" make me question ur diagnoses. Please clarify, no start, or, no crank.
Until u do, I'll assume, u mean no crank; which would point to the starter.
But.... are u experiencing any other problems. ie: things that should work when key is on, but are not. If u have any of these problems, look at the ignition switch. Let us know.
Ray
Old 04-03-2008, 09:02 PM
It is a no crank problem and now it is intermittent. The other night I held the key in the start position for several seconds and it started and has started for the last several days. I know it will fail again it's just a matter of time. I checked with the dealer and they want over $350 in labor to do the job. Just thought one of the members had done the job before and could save me some time with a few tips.
Thanks
Old 04-05-2008, 05:34 PM
Exit32's Avatar
Exit32 Exit32 is offline
2004 Buick Rainier
Medium Red Metallic 5.3L V8 AWD
I don't know if this is helpful, but here's the official GM maintenance manual procedure for removing and replacing a V8 starter motor. Unfortunatley, I am unable to copy and paste the supporting illustrations that go along with this procedure:
Starter Motor Replacement 5.3L Engine
Removal Procedure
Disconnect the negative battery cable.
Raise and suitably support the vehicle.
Remove the rear steering gear crossmember.
Remove the wire harness from the wire harness retaining clips on the transmission oil cooler line bracket.
Remove the transmission oil cooler line bracket bolt.
Remove the right transmission cover bolt.
Remove the starter bolts.
Move the starter toward the front of the vehicle, and remove the transmission cover.
Remove the starter solenoid heat shield.
Tilt and rotate the starter in order to pass the starter between the transmission oil cooler lines and the engine oil pan.
Remove the starter solenoid nut (2).
Remove the starter lead (1) from the solenoid stud.
Remove the battery positive cable nut (2).
Remove the battery positive cable (1) from the starter solenoid.
Finish removing the starter from the vehicle.
Installation Procedure
Begin installing the starter between the transmission oil cooler lines and the engine oil pan.
Install the battery positive cable (1) to the starter stud.
Install the battery positive cable nut (2). Tighten the nut to 9 Nm (80 lb in).
Install the starter solenoid lead (1) to the solenoid stud.
Install the starter solenoid nut (2). Tighten the nut to 3.4 Nm (30 lb in).
Install the starter solenoid heat shield.
Slide the starter toward the front of the vehicle. Position the transmission cover to the transmission.
Position the starter to the engine
Install the starter bolts. Tighten the bolts to 50 Nm (37 lb ft).
Install the right transmission cover bolt. Tighten the bolt to 9 Nm (80 lb in).
Install the transmission oil cooler line bracket bolt. Tighten the bolt to 9 Nm (80 lb in).
Attach the wire harness to the wire harness retaining clips on the transmission oil cooler line bracket.
Install the rear steering gear crossmember.
Lower the vehicle.
Connect the negative battery cable.
Document ID# 901544
2004 GMC Truck Envoy - 4WD
'67 Camaro SS small-block
9.07 sec. ET @ 146.85 mph
Old 05-05-2008, 02:23 PM
Thanks, for the help. I got in the truck this morning and "no crank". Looks like this week I get to replace it.
Old 05-05-2008, 02:34 PM
chevytech04 chevytech04 is offline
2004 Chevy TrailBlazer LT
Yep, if there is no clicks in stater solenoid. The starter is no good. Replace the starter and it will be fine again.
Old 05-05-2008, 04:36 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
I would smack that sumbitch with a hammer while a (preferably hot) assistant holds the key in the start position....i say this because a similar experience led to me buying a starter I didnt need....my intermittent no crank was due to a poor battery terminal connection
Similar Threads
Remote Starter Recommendations jc29ems Audio and Electronics 14 09-10-2012 08:52 AM
Remote Starter LBlazeIII Audio and Electronics 7 02-24-2008 03:06 PM
Need some help...starter...I think RedRocketZ28 OEM Issues 4 02-14-2008 05:09 PM
Remote car starter 05 TB Starr167Trail Audio and Electronics 13 02-10-2008 12:40 PM
Remote starter problem camaro Audio and Electronics 2 01-11-2007 10:53 AM
