exterior temperature reading stuck - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-06-2008, 09:53 PM
redneckrod redneckrod is offline
2003 Chevy TrailBlazer LT EXT
Cool exterior temperature reading stuck
I just wanted to let y'all know, I had a problem with the exterior temperature reading being stuck on 39 degrees on my climate control unit (I have the automatic climate controls.) I read a thread from another member that suggested to reset the sensor by pressing the "mode, front defrost, and rear defrost" buttons all at the same time. This instantly fixed my problem and prevented me from having to buy a new sensor and installing it. Hope this helps someone else! FYI: When this procedure was used, it reset the temperature to 70 degrees and then it started to drop until it reached the actual outside temperature.
Old 04-06-2008, 10:01 PM
DucatiSS DucatiSS is offline
TrailVoy Guru
1969 Rambler Rogue
Camo Other 2WD
Great info, see since you joined you are already smarter...
Gone to a better place
Old 04-07-2008, 12:36 AM
Chevy-TB-lover's Avatar
Chevy-TB-lover Chevy-TB-lover is offline
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
OMG thank you, thank you, thank you!
My temperature has been reading 50 degrees for the past year and a half! and now its fixed!
Old 04-07-2008, 12:59 AM
FJPTB's Avatar
FJPTB FJPTB is offline
2002 Chevy TrailBlazer LT
Forest Green Metallic 4.2L I6 2WD
Is there a procedure to reset the sensor for those of us without digital controls? I have this same issue on my temp. on the rear view mirror. I was going to buy the sensor this week sometime but dont want to waste the cash if its fixable.
2002 Chevrolet Trailblazer- I6, 2wd, 3.73's. 195,000 miles as of 09/1/09
Old 04-07-2008, 06:01 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
I'm unsure if there is a procedure to fix the regular one other than pulling fuse or disconnecting the battery.
I do know that if the sensor is bad you usually get the letters OC in the display indicating Open Circuit.
Bill
trailvoy.com
Let's get a Meet going!
Old 04-07-2008, 07:13 AM
FJPTB's Avatar
That sums it up for me then. I have been getting that "OC" for a few months now.
Old 04-11-2008, 06:38 PM
thatguy thatguy is offline
2003 GMC Envoy SLT
Black 4.2L I6 2WD
Thats awesome, mine has been stuck on 50. Brought it to the stealership today. They told me it was the sensor, so they changed it. Then they came back and told me the controls were also broken. $400 for controls, i said no thanks, bastards
Old 04-15-2008, 10:52 AM
MattyDennis03 MattyDennis03 is offline
2004 GMC Envoy SLT
Carbon Black Metallic 4.2L I6 4X4
is it the same buttons for an envoy because i cant get it to work
Old 04-15-2008, 03:54 PM
cbwilsha cbwilsha is offline
2003 GMC Envoy SLT
Pewter Metallic 4.2L I6 2WD
Yes, it's the same buttons for an Envoy.
C.B.
Old 04-15-2008, 05:17 PM
mikepc2fla's Avatar
mikepc2fla mikepc2fla is offline
2002 GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
How awesome!...IT WORKED!! Was going to have the dealership take a look at this towmorrow while I was getting the oil changed...saved some $$$...awesome!
THANKS!
You may not post new threads
You may not post replies
Similar Threads
A/C not blowing cold and Digital Temp reading is way off!! Onsite OEM Issues 9 05-03-2010 12:08 PM
[SOLVED] hvac stuck at hot/ mode door inop MAY03LT General 4 04-26-2009 11:16 PM
Got stuck again! 14hateboy88 TrailBlazer / Envoy Chat 0 01-30-2008 11:20 AM
Need help identifying problem: incorrect exterior temperature reading momofrocky General 2 08-29-2007 06:12 PM
Reading light problem 04MaroonTB Interior 3 05-08-2007 03:14 PM
