Bellhousing bolt pattern? Manual trans? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 04-07-2008, 01:44 AM
RamAirZ RamAirZ is offline
1999 Camaro Z28
Navy Blue Metallic Other 2WD
Alrighty, did alot of searching and some people say to use a colorado bellhousing to bolt a manual trans to the I6. Is the bolt pattern different than your typical GM bellhousing? I'm going to be putting this into a 67' chevy and megasquirt so no fooling the computer to worry about or shifter placement. I have an SM420 4-spd (granny low, high crawl ratio) that I want to keep behind it. Anyone have any information on something like this? My only concern is input shaft length being too long or too short (rather have too short and get fix that).
Old 04-08-2008, 05:32 PM
starchief1959's Avatar
starchief1959 starchief1959 is offline
2005 Chevy TrailBlazer LS EXT
Our tranny is standard chevy "barn roof" bolt pattern. Not too sure about shaft lengths though, not very familiar with the SM420.
Where there's a will there's a way.
"Why aren't you capturing the boy?"
"Cause I have a big head, and little arms."
Old 04-08-2008, 05:55 PM
1999 Camaro Z28
its the dumb starter that is going to give me problems, hmm. The SM420 is a granny low manual tranny, basically a muncie.
Old 04-08-2008, 09:11 PM
Find your input shaft dimensions and match it to an existing GM tranny (mot any chevy bellhouing will mate up). Being that the SM420 is considered GM it shouldn't be a problem making a match. That bellhousing should work for you and enable you to use the starter matching that bellhousing with your tranny. You might have to have a custom flywheel made cause I don't know the bolt patern on the TB, nor the teeth. The only thing you have to worry about now is starter clearance in the vehicle and being a '67 shouldn't be too hard.
Here's a site that might offer you some help.
http://www.novak-adapt.com/knowledge/sm420.htm
Old 04-08-2008, 11:00 PM
Greg55_99 Greg55_99 is offline
2003 Non-GMT360 Other
Fire Red Other 2WD
The Chevy bellhousing pattern is NOT the same as the 4200, although, with a fabbed adapter plate, it CAN be made to work.
Greg
Old 04-09-2008, 01:06 AM
1999 Camaro Z28
The dowel pins are the same but the pattern is off and the starter is mounted upper/middle drivers side whee as all other chevys are lower passenger. I'll figure something out
Old 04-09-2008, 08:35 AM
I thought we had the 4L60E tranny. That's a standard GM tranny with same bellhousing as 700R4, TH350, TH400, etc. They changed it?!? Retarded engineers. Out fixing things that aren't broken again.
As far as your starter, a new bellhousing will move it. Or like Greg said, an adapter plate. BOPs mount on the driver side so I'm sure it could be done.
Wilcap is the best tranny adapter company out there. There's a guy here in MN call Bendtsens (sp) but he's a total rip-off.
Old 04-09-2008, 03:53 PM
1999 Camaro Z28
The bellhousing is removable on the 4L60E after 98'.
Old 04-09-2008, 04:41 PM
limequat limequat is offline
Senior Member
1987 Non-GMT360 Other
n/a 4.2L I6 2WD
Why not use the Colorado trans? It'll bolt up. You just need a flywheel.
Old 04-09-2008, 05:22 PM
1999 Camaro Z28
Because I want to keep teh SM420 with rockwell transfer case in my truck. The colorado 5-spd wouldn't last a week in my truck lol.
Similar Threads
6x5 and 6x5.5 bolt pattern SiNgHsAnE Rims 5 03-01-2008 03:07 PM
Bolt pattern supergeess Rims 6 08-21-2007 04:24 PM
Is Changing the Bolt Pattern a Problem? BUC NASTY Rims 11 03-16-2007 03:57 PM
03 Bolt Pattern Different? 03Blaze Rims 4 03-15-2007 03:17 AM
Has anyone tried adapters for bolt pattern? JJKJ Rims 4 11-01-2006 05:44 PM
