Squeaking sound on drivers side front - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 04-09-2008, 12:07 PM
lineman82's Avatar
lineman82 lineman82 is offline
2005 Chevy TrailBlazer LS
I have a 2005 TB 4x4. I have a sqeaking (metal on metal) sound coming from my front left side. It is very noticable when driving a slow speeds on a rough road. It makes the sound when the suspension is traveling up and down due to the bumpy road. At high speeds its gone. I have checked and the ball joints appear to not have any play in them. It almost sounds like its coming from the top of the strut assembly. I have checked and the top perch bolts on the frame mount are tight. Any tips?
Old 04-14-2008, 07:16 PM
JR4815D2's Avatar
JR4815D2 JR4815D2 is offline
Senior Member
2005 GMC Envoy SLE
Black 4.2L I6 4X4
Ok, so after reading through the forum, I wasnít able to find any information to this one problem I have with my Envoy. Recently in November, I changed my stock shocks to HD Bilstein Shocks. The ride was great, but recently the ride has become very bad. One of many problems with the envoy. Just last few days, I was cleaning the Envoy and I put some degreaser on the front of the Engine bay. Washed thru and the next day I started to get this noise. It took a while to figure out where it was coming from, Sure enough it was the front. Itís hard to describe unless I have some sound clip. Therefore, this morning I was able to get a small recording. It sounds like its coming from the front shocks. Itís from both sides. These shocks are new and donít have much mileage on them, but is it possible that they are done. Any help would be greatly appreciated.
The sound bite is me pushing the front of the envoy down several times. Like the other member said when going slow on turns or bumps this happens.
Download 0414081229.wav
Old 05-13-2008, 07:19 PM
clason's Avatar
clason clason is offline
2004 Chevy TrailBlazer LT
Sandstone Metallic 4.2L I6 4X4
i have an 200 4X4 TB and also have the same exact sound coming from the front of my Trailblazer, i have done nothing to it yet because i just recently purchased it, it only has 47K on it.
Old 05-15-2008, 09:59 AM
rudeboy rudeboy is offline
2003 Chevy TrailBlazer LT EXT
Midnight Blue Metallic 5.3L V8 4X4
hey guys im new here but i have the same problem. its the upper control arm bushings. whenu go outside to your truck, have someone turn the steering wheel and u will actually see the bushings moving out of place.
Old 05-15-2008, 10:07 AM
Old 05-20-2008, 11:40 AM
tomek38's Avatar
tomek38 tomek38 is offline
New Member
2003 GMC Envoy SLT
Medium Sage Green Metallic 4.2L I6 2WD
If you are sure about shock(it looks for me) check the Wheel Hub Bearing
Just lift the front of the car and try to push your wheel from outside to inside and just roll it. This should indicate the source of the problem.
If still nothing just take any long piece of metal and try to lift you control arms and observe if any of bushings aren't fine
Old 05-20-2008, 12:26 PM
lhassebrock lhassebrock is offline
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
This might not relate to what you guys are experiencing, but I had a squeak I couldn't figure out for the longest time and after an exhaustive search realized it was the hood stops. As on any vehicle there's two hood stops that rest in depressions in the hood. Over time dirt an rubber get deposited in the depressions and make them squeak like crazy when going slowly over bumpy terrain. I just cleaned them out and lubed them up with a little grease. This might not be what you are experiencing, but you might as well check the easy things before a repair shop gets into you
Old 06-21-2008, 11:51 AM
baardaap's Avatar
baardaap baardaap is offline
New Member
2004 Chevy TrailBlazer LTZ
Hello,
Had similar problems , it took some time but itís solved now,
see http://forums.trailvoy.com/showthread.php?t=3608
Old 10-30-2016, 05:45 PM
MMS2016 MMS2016 is offline
2003 GMC Envoy SLE XL
2003 Envoy XL. - 109K great shape
Hello all. I have been a member only recently but found all of your advice very helpful. I hope I can contribute something useful from what I experienced with our Envoy XL.
I agree with rudeboy. Occasionally Our Envoy will get a squeak as the suspension cycles, or when you hit the brakes. Once it started, it progressively got worse. After a few weeks I took it up to the repair shop and they tried selling me a set of struts, but I was not convinced. I made another test and inspected the strut under motion (rocking motion) and everything appears to be working fine and settled / dampened well. Also, I found no strut leaks. So I decided to put a jack under it and take a more detailed look. I had someone cycle the steering both right and left while I observed the suspension and was able to hear the creaking sound only at full stop. i could see the lower control arm bushing deflecting slightly and the sound was like fingernails on a chalkboard. Next I applied a solvent free lubricant called Fluid Film
at all the suspension pivot points. The squeaks are gone.
Similar Threads
Driver's side carpet soaking wet! TBlazeruss44 General 30 03-07-2017 02:09 PM
Creaking/squeaking sound in front end when braking Braves299 General 12 02-11-2016 01:58 PM
cazy grinding sound from front end Troubleshooter OEM Issues 13 06-15-2007 01:39 AM
Squeaking Front Wheel Element Rims 2 08-06-2005 09:53 PM
Jiggle noise by the rear driver's side door? New to TB Interior 6 07-22-2005 08:56 AM
