Testing Coil Pack? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-11-2008, 07:32 AM
rg567 rg567 is offline
2002 GMC Envoy SLT
Testing Coil Pack?
My 02 Envoy has a little miss at idle and I'm begining to suspect one of the coil packs is to blame. Is there any way to test these coils with a fluke meter or anything else?
Old 04-11-2008, 07:55 AM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
I have been wondering the same thing. I had a miss too, but it never set a code, so I didn't know which coil it was. I ended up changing all six and that solved the problem (got them cheap on eBay).
Old 04-20-2008, 01:53 AM
jurassic3k jurassic3k is offline
Fire Red 4.2L I6 4X4
I just changed my plugs and one of the coils was rusted. No missing that I can detect but it might need to e replaced. Any ideas on the cost?
Old 04-20-2008, 03:31 AM
Coach Steve's Avatar
Coach Steve Coach Steve is offline
Senior Member
2003 Isuzu Ascender
Blue/Silver Two-Tone 4.2L I6 2WD
They're right around $55.00 each at RockAuto.com
"SHUT UP AND LISTEN - You can't learn anything while you're talking!"
Old 02-01-2012, 05:11 PM
scoulter4's Avatar
scoulter4 scoulter4 is offline
Black Granite Metallic 4.2L I6 4X4
Is there a brand that everyone recommends? Obviously beside OEM for the coil packs?
Old 02-01-2012, 09:08 PM
TrailblazrI6 TrailblazrI6 is offline
Moderator
Summit White 4.2L I6 4X4
With something like the coilpack, an OEM Delco is always preferred. However, Ive been using a Duralast from Autozone for 4 or 5 years now with absolutely no issue.
The real issue is getting to the coil pack failure; was it a result of a bad hood seal causing water to leak onto/into the spark plug wells and shorting out the coil pack, a bad valve gasket causing oil to leak in the wells and short out the coil pack, or just age?
If you have requests, need to report SPAM or need to tell me something in confidence, please PM me.
Happy Trailvoy'ing!
Similar Threads
How to: Replace blower resistor pack replacement WITH PICS! K2JJB The 02-09 "How-To" and DIY Section 718 03-23-2017 11:22 PM
coil spacer help gotspeed1 Suspension 2 04-23-2008 09:40 PM
Coil Lifts...? jhj521 Suspension 6 01-19-2007 09:43 PM
Battery isolator coil connection jzdt8x General 1 10-02-2006 05:36 PM
2wd/4wd coil question goes211 Suspension 4 01-26-2006 07:25 PM
