HVAC Mode Actuator door replacement - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 04-12-2008, 02:47 PM
03Huggy's Avatar
03Huggy 03Huggy is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
I just replaced my mode actuator due to the dash vents not working; it wasn't too bad of a job; you just need to be patient and smart as you work.
First you need to find out what part number to order; just call the local GM dealer. you will need to give them your VIN; the P/N I used was 89018675 and I got it from www.parts4chevys.com for $46.33 which was alot cheaper than the dealership.
Remove lower dash covers. The actuator is located behind the middle portion of the dash; if you lay on the floor and look to the left you will see it.
Remove gray air duct as shown in pc #53; just pull it from it's endpoint; this way you can get to the actuator better.
There's 2 actuators; you want the one with the white gear coming out the side; it's the lower one in pic #52. You will need a 5.5mm socket to get the 2 screws out; be careful not to drop the screws; take your time.
Pic #46 shows the actuator; the two horizontal holes are where the screws mount; the other one close to the wire connection has a dowel that helps locate the actuator. You will need to adjust the white gear shown in pic #46
to be at the same location as the gear on the actuator you removed in order for it to go back in correctly. There are 3 marks on the back of the plastic housing (as seen in pic #46) and also slots in the metal part of the gear drive, the top slot is in the 1'oclock position in pic #46. Be sure your new actuator gear position matches the old and it will drop right in. I put the screws in the socket and then wrapped electrical tape around them so the screw wouldn't fall out during assembly. The whole thing took me 45 minutes.
The vents now work like a charm and I saved a bunch of coin!
You can doooo eeeet!
Click image for larger version
ID:	503   Click image for larger version
ID:	504   Click image for larger version
SS wannabe
Old 04-12-2008, 09:12 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
Great write up! This is one of my favorite tips too
Old 05-09-2008, 01:49 PM
LeonPhelps's Avatar
LeonPhelps LeonPhelps is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Where is the world do you find a 5.5mm socket ?
Old 05-09-2008, 02:14 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
[QUOTE=03Huggy;535686] the P/N I used was 89018675 and I got it from www.parts4chevys.com for $46.33 which was alot cheaper than the dealership.[QUOTE]
GMPartsdirect.com GM LIST: $66.12 OUR PRICE: $34.38
Old 06-14-2008, 09:30 PM
waltkivbulk waltkivbulk is offline
New Member
2003 GMC Envoy SLE
Carbon Metallic 4.2L I6 4X4
Lay on floor and look to left ---- From Driver or passenger side?
Old 06-15-2008, 02:26 AM
stanley2 stanley2 is offline
2003 Chevy TrailBlazer LT
Emerald Jewel Metallic 4.2L I6 2WD
Driver side looking to the center console; to the left.
Bilstein HD, K&N CAI 57 with gutted air box, Alpine IVA-W205 HU GT5-4.10 gears G80, 6000K HID Lows and Fog, PCMForLess,
Old 06-15-2008, 06:42 PM
EXT 03 EXT EXT 03 EXT is offline
2003 Chevy TrailBlazer LT EXT
Dark Gray Metallic 4.2L I6 2WD
When the motor goes bad does it cause a clicking sound?
Old 06-16-2008, 12:17 AM
Yes mine did a soft clicking.
Old 06-16-2008, 10:30 AM
chevy2000's Avatar
chevy2000 chevy2000 is offline
2002 GMC Envoy SLT
03Huggy, what prompted you to replace the Actuator? Currently my wifes '02 Envoy makes a clicking sound when you changes modes, like from the upper vents to the lower vents, etc. The air still comes out, but it makes the clicking noise like it is binding as it is changing positions. I didn't know if this is what you were experiencing or not?
Thanks
Old 06-16-2008, 11:07 AM
wbsterritt's Avatar
wbsterritt wbsterritt is offline
2003 Olds Bravada
Summit White 4.2L I6 AWD
5.5mm socket
comparable to a 7/32" standard.
Similar Threads
HVAC Mode Door potts200 Interior 78 09-15-2016 11:45 AM
HVAC Mode Actuator stanley2 General 18 02-19-2016 01:56 PM
Envoy HVAC Mode Actuator nixdorf Interior 9 07-19-2015 12:52 PM
[SOLVED] hvac stuck at hot/ mode door inop MAY03LT General 4 04-27-2009 12:16 AM
