HVAC Mode Actuator door replacement - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 07-23-2008, 04:45 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Originally Posted by ENVOY2003SLE View Post
hi, great forum, thanks for all the great info. i hope this thread is the answer to my problem and i hope others can give me ideas.
2003 sle envoy. i recently (well last few months ) am only able to have A/C or heat come out of the front vents on the 3rd setting on the nob. A/C and heat works but only blows out strong on 4th and 5th setting and NOW today only on the 5th setting. before i had the battery die and had throttle problems and was able to fix it with a good cleaning of it...thanks to the forum. do you think its the " mode door actuator " that needs to be replaced? i too have had the clicking sound but strange as it might be only time i hear it is during the winter months. thanks for any help and great forum with great info.
Hi, welcome to the site.
The mode doors only control the direction of the air flow (floor/vent/dash), have nothing to do with the fan speed.
It sounds like you are having a problem with the fan speed control module. I think it's called a blower motor resistor assembly. Very common problem, it's a $25.00 fix (if u do it yourself) and located under the dash, behind the glove box. Lots of info on here, and some pictures. Try a quick search, the more recent threads are the ones to view.
You may also have a mode door problem, but the speed thing is the resistor assembly.
Ray
Old 07-23-2008, 10:53 PM
ENVOY2003SLE ENVOY2003SLE is offline
2003 GMC Envoy SLE
Black 4.2L I6 4X4
thanks for your reply. after posting i did some more reading and there was someone who also had or has the same problem. the vent would or seem to not have any air/heat/ac coming threw when i turned the nob on. setting 1,2,3, now 4 acts like the off position and 5 is the only setting that pushes anything out. i'm hoping that the person who also had the same problem post a reply. do you know of any good places in Canada to buy parts besides places like CrappieTire? i also need to replace the spare tire carrier. seems like this truck needs some upkeep.
thanks
  #23
Old 07-24-2008, 10:56 AM
gdewit79's Avatar
gdewit79 gdewit79 is offline
Senior Member
2004 Chevy TrailBlazer LT
Light Tarnished Silver 4.2L I6 4X4
Originally Posted by 03Huggy View Post
All the work is done from the drivers side.
Read my initial post again; it was due to the dash vents not working. The actuator door allows air to go to the dash vents and floor vents.
The problem with mine is the dash and defroster vents work, but I have no floor vents.
  #24
Old 07-27-2008, 12:37 AM
2003 GMC Envoy SLE
Black 4.2L I6 4X4
and yes it was the resistor, thanks for everyones help. great forum !!!
  #25
Old 08-04-2008, 10:49 AM
yar02169 yar02169 is offline
2002 Olds Bravada
Indigo Blue Metallic 4.2L I6 AWD
Hot & cold at the same time
I've been searching high and low, and I'm hoping the pictures here will help. I get air through the various vents, but on the drivers side it's only warm air while the A/C works fine on the passenger side.
By looking at the directions and pictures, can I assume that the upper actuator is the one that I will need to replace to get cold air out of the driver's side vents?
The pictures do help, if it wasn't for them I wouldn't know what to look for. My Chilton's manual is useless in providing any help on this subject.
  #26
Old 08-08-2008, 01:59 PM
blzr0213 blzr0213 is offline
Same here, drivers side blazing hot, passenger and rear nice and cold. This also happened the same day the battery had to be replaced. Has anyone had this problem and fixed it?
  #27
Old 08-08-2008, 04:21 PM
fife2001's Avatar
fife2001 fife2001 is offline
2002 GMC Envoy SLT
I have the same problem.....I also cannot turn the defroster vents off if I want.
I did replace the mode door actuator and it clicks less but still does not work correctly.
I think the actuator works but the door itself cannot move the whole range for some reason.
  #28
Old 08-15-2008, 11:44 PM
quirino18 quirino18 is offline
Originally Posted by LeonPhelps View Post
Where is the world do you find a 5.5mm socket ?
use a 7/32 you find wrenches at sears or sockets also
  #29
Old 09-07-2008, 05:54 AM
toenizzle toenizzle is offline
New Member
simlar issue with 02 tahoe
I have the same issue with my 2002 tahoe, where the air only blows from the defroster vents and the feet vents. does anyone know if this procedure will work on the 2003 tahoe as well?
  #30
New Member
oops, i meant 2002 tahoe not 2003
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
You may not post new threads
You may not post replies
Similar Threads
HVAC Mode Door potts200 Interior 74 02-06-2013 12:32 AM
HVAC Mode Actuator stanley2 General 16 06-29-2012 03:33 PM
Envoy HVAC Mode Actuator nixdorf Interior 6 07-03-2011 11:36 AM
[SOLVED] hvac stuck at hot/ mode door inop MAY03LT General 4 04-26-2009 11:16 PM
