P0332 knock sensor code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-03-2008, 08:06 PM
lifted4x4astro's Avatar
lifted4x4astro lifted4x4astro is offline
2005 Chevy Other
Summit White Other AWD
Question P0332 knock sensor code
My wife's 2005 TB is now throwing a P0332 knock sensor code. I was hoping it was being caused by the 2 bad front wheel hub bearings and that it would go away after replacing them. This piece of crap only has 62k on it and there are all sorts of issues!
I am looking for info on where the knock sensor is, how to test it (with dvom) and a possible part number to replace it with. I looked on GMPartsdirect.com and it list 2 different ones. These are cheap enough, I just hate to buy them both and never need the second one.
Thanks in advance for any help.
Old 05-04-2008, 11:24 AM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
I doubt the wheel bearings would trip the knock sensor. You might be able to test it by hooking a scope to the output of the sensor and gently tapping the block with a SMALL brass hammer near the sensor. At that time you would see a spike on the voltage output of the sensor. Do you hear the engine knocking? It just might be a bad sensor. The idea is the sensor senses the knock and backs off the timing to stop the ign. knock and if it continues to knock it sets a code.
Robert
Old 05-05-2008, 02:59 AM
2005 Chevy Other
Thanks for the info. Any idea where it is located?
I did find this pic in another thread. Is it one of these sensors? Are there more than 1 knock sensor?
Old 05-12-2008, 07:16 AM
2005 Chevy Other
In the pic, the knock sensor is #2 and is located on the left side of the engine, to the rear and just under the starter. The GM part number is 12567446 and was $35.21. Very easy fix.
Old 07-17-2009, 06:30 PM
ubuthedog's Avatar
ubuthedog ubuthedog is offline
2003 Chevy TrailBlazer LT EXT
Graphite Metallic 5.3L V8 4X4
any info on the 5.3 knock sensors im getting code p0332 and dont know what to look for
I know my engine isnt knocking, does feel a little sluggish but not bad, mpg's seem ok
Old 07-17-2009, 10:45 PM
2003 GMC Envoy SLT
If the knock sensor is doing its job, you won't hear the knocking. See post #2. The timing being retarded will cause engine sluggishness.
Old 07-17-2009, 10:59 PM
ubuthedog's Avatar
yeah i re read the post, i also found one letting me know they are under the intake really not looking forward to doing this one... thanks
Old 09-16-2009, 06:24 AM
Chiefw3 Chiefw3 is offline
2006 Chevy TrailBlazer LT EXT
Black 5.3L V8 4X4
any news?
My engine (5.3) is doing the same no knock but the P0332 code is present. Did changing the sensor solve the MIL issue? Which one is the #2 on the 5.3?
Thanks!
Old 09-25-2009, 10:40 PM
ubuthedog's Avatar
didnt change it, it went off on its own and never came back
I am however getting better mileage and more power not much but easily noticed the difference
Similar Threads
Engine knocking / Tapping noise coastie22 OEM Issues 317 09-04-2013 02:30 AM
cylinder knock dawson8079 Engine Tunes/Mods 11 03-28-2008 07:28 AM
engine knock????? tiko_joe OEM Issues 16 11-21-2007 09:20 AM
Engine Knock OSO1000 02-09 Vortec 4.2L I-6 Engine and Drivetrain 7 10-27-2006 07:00 PM
