Wet Passenger Side Floorboard - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-25-2008, 12:02 PM
skone skone is offline
Anyone know what would cause the passenger side floorboard to get extrememly wet? I don't believe it is a heater core because the liquid is water. My guess is condensation from the A/C, but how does it leak back inside? What do I need to do to fix it?
Old 05-25-2008, 12:10 PM
CWBYTAZ1 CWBYTAZ1 is offline
New Member
2007 Chevy TrailBlazer SS
Silverstone Metallic 6.0L LS2 V8 2WD
Does your TrailBlazer have a sunroof?
Old 05-25-2008, 02:04 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
I think your right, AC condensation. There is a drain hose, under the hood, on the firewall, passenger side. If plugged, the water goes into the truck.
There is a place where the heater and ac hoses & pipes go through the firewall, the drain is the hose on your right as you view the firewall.
Ray
Old 05-25-2008, 02:46 PM
parrothead's Avatar
parrothead parrothead is offline
2004 Chevy TrailBlazer LT
Indigo Blue Metallic 4.2L I6 2WD
This may be the cause. I know sometimes there is a quite a puddle under my TB and traced it to the hose that runs next to the condenser. I imagine if that hose was clogged alot you would see alot of water.
Do you notice more water collecting on the floor after it rains? If you do there may be a leak or blockage somewhere else.
Old 05-25-2008, 05:22 PM
the roadie's Avatar
Yep. There's a flap valve in that tube and if it's pulled out towards the front of the vehicle at the firewall, it drains inside instead of to the ground. Happened to me once, and it drained about a quart when I figured it out and pushed the hose back in tight. Need a picture? It's sort of obviously near the receiver/dryer.
Old 05-25-2008, 05:29 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
i use a thick zip tie to break up any debris in the tube
Old 05-25-2008, 10:52 PM
Yeah, I found that house and as soon as I removed it a lot of water drained out. It was like I removed the plug from a tub. I figured it was clogged and blew the hose out, but it was fine. There was no clog. I am not sure why it wasn't draining, but after I reinstalled it I verified it was draining. I guess we will see what happens. Thanks for the posts.
Old 06-17-2009, 10:43 PM
markwint04 markwint04 is offline
I have the same problem.. I will try to look for the hose..
What a great site this is just to be able to fix it yourself .. I love this site
Old 06-17-2009, 11:05 PM
the roadie's Avatar
Old 06-18-2009, 05:39 AM
Much thanks!
Similar Threads
Great site Shiboi Introductions 14 02-21-2006 11:59 AM
Anybody heard of this site??? Trailblazin Everything Off-Topic 8 09-29-2005 04:05 PM
Hello All, Great Site EJG Introductions 11 08-08-2005 09:59 PM
Hosting site at home... Manbir Sandhu Everything Off-Topic 12 07-13-2005 11:59 AM
I LIKE THIS FORMAT & SITE thecarbonman TrailVoy.com Site Issues and Support 10 05-19-2005 09:35 PM
