engine wont start - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-26-2008, 11:42 AM
JDuB84 JDuB84 is offline
2003 Chevy TrailBlazer LS
Dark Gray Metallic 4.2L I6 2WD
engine wont start
Hey hows it going!? I have an 03 Trailblazer. The engine will crank but wont start. All the fuses are good. The fuel pump wont run when i turn the key on...I checked power to the fuel pump and dont have it there. I got a book on trailblazers and it says to check the fuse and relay (I did and both are good) and if they are good to check the fuel pump relay control circuit from the electrical center to the PCM. My question is how exactly do i check the fuel pump relay circuit from the electrical center to the pcm?? Any help would be great and appreciated!! Thanks
Old 05-26-2008, 08:10 PM
Jozuah's Avatar
Jozuah Jozuah is offline
Senior Member
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
the fuel pump will only run a few seconds after the key is turned on so if you are looking at the plug with a test light then thats prolly why your not seeing power to the pump.
the best way to check fuel pump power at the plug would be to have a "helper" turn the key on while you pin out (test) the plug for power having the helper cycle the key on for 2 seconds off for 2 seconds.
IF then you dont have power to the fuel pump (VERY rare occurance but not impossible) then i would start testing wires from the fuse box to the pump for continuity with a meter.
if they show broken , then repair or replace as necessary.
*DISCLAIMER* i have a migraine i think and if i misunderstood your question or seem all jumbled in my response im sorry in advance.
there is no replacement for REAL LIFE experience!
2004 Trailblazer resonator removed
PCMFORLESS tuned
Old 05-26-2008, 09:57 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
couldn't it also be a bad fuel pump? have you changed the fuel filter lately? severely clogged filters can cause pumps to go bad.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 05-27-2008, 06:12 PM
yea i had someone helping me and we found no power going to the fuel pump. so ill check the wires for continuity and see what i can find and go from there. thanks for the help and if i have any other questions or problems ill let you know.
Old 05-30-2008, 11:47 PM
tbblue tbblue is offline
2007 Chevy TrailBlazer LT
Hi
I had similar problems starting my 07 lt.
It turned out that the crank scensor conector was loose
and the harnes to the pcm was also loose.
TBBLUE
07 lt i6
Old 06-03-2008, 04:32 PM
neelskit's Avatar
neelskit neelskit is offline
2002 Chevy TrailBlazer LT EXT
Pewter Metallic 4.2L I6 4X4
Might be a corroded ground?
Similar Threads
Normal Engine Noise? 05LT OEM Issues 17 01-28-2013 02:58 PM
03 Trailblazer engine stalling while driving Ms03Trailblazer OEM Issues 20 10-10-2012 06:21 PM
02 Bravada strange engine stall revisited Moebius OEM Issues 22 10-02-2012 11:04 PM
New noise at start up coolcloo1019 OEM Issues 5 05-21-2008 12:40 PM
No Start Condition... Dacomputernerd 02-09 Vortec 4.2L I-6 Engine and Drivetrain 8 10-04-2006 09:01 PM
