AC Leak? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-27-2008, 04:43 PM
shawn418's Avatar
shawn418 shawn418 is offline
2003 GMC Envoy SLT XL
Summit White 4.2L I6 AWD
AC Leak?
Is there a way to look for leaks in the AC Unit? I have had issues in the past and have replaced the Low Pressure Sensor and charged with refrigerant. I checked the pressure this afternoon and have no pressure on the low side. Any clues and help would be appreciated.
Old 05-28-2008, 12:20 AM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Put a UV dye in the system, recharge, and run it. Then use a UV light. Where the leaks are will glow.
Robert
Old 05-28-2008, 10:54 AM
shawn418's Avatar
Will stop leak fix the problem?
Old 05-28-2008, 10:56 AM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Old 05-28-2008, 11:23 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
There's a good chance that you'll wind up w/ additional component failures...best thing to do is fix the problem
BTW...I do not believe in any of the stop leak products; they may work, but the problem should be fixed, not temporarily masked
-Mike
AKA PROVY
Rock On!
Old 05-28-2008, 05:47 PM
shawn418's Avatar
Looks like it is a leak. What is usually the cost of repair? I do have an extended warranty but it only covers the evaporator, condenser, compressor, compressor clutch, and seals/gaskets for covered parts. What are the odds that it is one of these?
Old 05-28-2008, 06:46 PM
PROSPHOTO's Avatar
The odds are pretty good that it's a component leaking...unless something bounced up under the hood and blasted a line
-Mike
AKA PROVY
Rock On!
Old 05-29-2008, 01:24 PM
shawn418's Avatar
Well it's even worse. I have a busted discharge hi-pressure hose that runs to the rear air. Dealer says this hose is under the frame and the frame and body need to be separated in order to fix. They say I also need a receiver drier. Total cost for this at the dealer..................$1700.00. And of course it's not covered under my warranty. Any ideas?????
Old 05-29-2008, 01:35 PM
petevw's Avatar
YIKES!! I think I'd be getting a second opinion on the repairs.
Old 05-29-2008, 02:33 PM
shawn418's Avatar
I have a call into an independent service station. Hoping the costs come down. I am however going to the dealer to complain. I've had the truck for 3 1/2 months and have already spent about $1000.00 in repairs. Not sure if it'll do any good but may make me feel better bit@#ing them out. I can't see that if they do their checks when they get cars/trucks in that they could miss this.
Similar Threads
water leak soprani99 TrailBlazer / Envoy Chat 1 03-15-2008 11:17 AM
3rd week and oil leak jmoudry OEM Issues 3 01-28-2008 08:07 PM
Bad Day With Tranny Leak DAPABEYS OEM Issues 11 09-02-2007 05:34 PM
95 GMC Jimmy Coolant Leak Aerostud1026 Everything Off-Topic 2 06-13-2007 10:22 PM
Gas Leak question xceebeex 02-09 Vortec 4.2L I-6 Engine and Drivetrain 13 01-09-2007 12:25 PM
