HVAC Mode Actuator - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-31-2008, 02:56 AM
stanley2 stanley2 is offline
2003 Chevy TrailBlazer LT
Emerald Jewel Metallic 4.2L I6 2WD
HVAC Mode Actuator
So mine stopped working, after reading here about it and using the method of taking the HVAC B fuse out, and not work, I took it out, it is marked:
HL 52402610
010030422A
Is this the part No.
Also, does any one know where to buy that ships international to Mexico city zip 08300?
It is a manual control.
Thanks
Bilstein HD, K&N CAI 57 with gutted air box, Alpine IVA-W205 HU GT5-4.10 gears G80, 6000K HID Lows and Fog, PCMForLess,
Old 05-31-2008, 10:08 AM
Envoyguy05's Avatar
Envoyguy05 Envoyguy05 is offline
2006 GMC Envoy SLE
Cranberry Red Metallic 4.2L I6 4X4
not sure if 52402610 is the part #. Is it a relay or a fuse?
Keith
Northeast Chapter MA Rep
K&N 63 Series, 6000k Hid lows and fogs, Magnaflow Cat -Back, 20's, G80
Old 05-31-2008, 11:12 AM
It is the door mode actuator that changes the exit of air from floor to front vents.
I been searching for both numbers with no luck.
Old 06-01-2008, 10:40 PM
Hi all, After looking in the forum I was able to find the following GM part numbers, can you help me define which is the one for the 2003 ls that moves the air from floor to front vents.
Thanks
GM 89018539
GM 89018525
GM 89018657
GM 89018675
GM 89018676
Old 06-04-2008, 01:34 AM
I am going crazy, which part should i order?? I have too many part No.
Please, your help will be greately apreciated.
Old 06-04-2008, 08:32 AM
AbsoluteZero AbsoluteZero is offline
2003 GMC Envoy SLT
89018675 is the p/n used on my 03 Envoy to fix no airflow from the upper level vents. The Envoy has auto a/c so can't verify it's correct for you TB
Old 06-04-2008, 04:18 PM
Well you were right, it is part No GM 89018675 and has to be ordered directly from plant.
Will have it by Monday and it cost $1,003.00mxp some $ 96.00usd
Old 06-06-2008, 04:03 PM
Hello all, I just got my Actuator, is there any thing I should know before installing it?? Tricks or tips will be greatly appreciated.
Thanks
Old 06-06-2008, 10:56 PM
Well Actuator is in and working perfectly!!!!!
The TB is like New again
Old 06-08-2008, 10:52 PM
kj4963 kj4963 is offline
New Member
2003 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 AWD
actuator
Is it a big job? i have the same problem. no airflow from center vents.
Similar Threads
HVAC Mode Actuator door replacement 03Huggy The 02-09 "How-To" and DIY Section 682 02-23-2017 10:41 PM
Envoy HVAC Mode Actuator nixdorf Interior 9 07-19-2015 12:52 PM
2003 TB HVAC Mode Actuator Door "Clicking" g8rfn Interior 10 07-31-2008 02:04 PM
