front end alignment specs... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-04-2008, 12:15 AM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
Dark Gray Metallic 4.2L I6 2WD
has a front end alignment and here are the specs.
----------left front----------------------right front
camber before--0.49x.....................before -0.64x
after----0.51x....................after- -0.66x
toe before -0.20.........................before0.06
after 0.04..........................after 0.02
i dont understand this spec sheet but was it bad before alignment? it rides so much better now.
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 06-04-2008, 11:50 AM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
what did the tires look like?
Old 06-04-2008, 12:04 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Doesn't really look like they actually touched the camber, they did however adjust the toe-in. You're toe was a little out of spec prior, which would cause the tires to drag and wear quicker than they should. Afterwards, you have a slight toe-out condition, which tends to aid turning or makes the vehicle more agreeable to turns. Adjusting the toe will sometimes cause a very slight difference in camber/caster, due to the angle of the tires with the wheel centered.......they basically gave you a toe alignment, but the camber was well within spec to begin with.
What you didn't provide is the caster numbers before and after, while which do not usually cause tire wear, can result in a drift or pull condition. Your camber is set that you'll have a slight drift to the right, not much by a very slight amount. Hopefully the tech left more caster on the right side than the left to more than compensate and setup a slight left drift for road crown. (Usually they'll give the passenger side more caster to allow it to creep up the crown just a bit).
Old 06-04-2008, 06:19 PM
rubberman's Avatar
really worn on the edges.
caster specs
LF......before-3.86.............after-3.86
RF......before-4.35.............after-4.35
Old 06-05-2008, 11:35 AM
Midwest Kid Midwest Kid is offline
Black 4.2L I6 2WD
Specs as Follows.. (to the best of knowledge anyhow)
FRONT Caster Min. 3 to 4 Max
Chamber -1 to 0
Toe -.05 to .15
The total of Toe In\Out shouldnt be less than -.10 and more than .30 apart from left and right.
Old 08-13-2014, 05:17 AM
AlianaPop AlianaPop is offline
2004 Buick Envoy SLE
Graphite Metallic 5.3L V8 4X4
thank you so much its really helped
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
07" envoy vibration in front end chance0830 OEM Issues 19 06-30-2009 10:00 PM
Front end alignment sjfd04 Suspension 1 06-25-2008 10:01 PM
Bra now for the 06+ LT front end? Spong Exterior 12 11-11-2007 02:21 AM
replaced front passenger end link Swearingsailor6 OEM Issues 2 07-25-2007 08:03 PM
different front end??? NORCAL SS Exterior 7 04-23-2006 02:32 AM
