Code P0302 #6 Misfire. Need Help! Changed Plugs and Coil. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-10-2008, 08:51 AM
carnorvor carnorvor is offline
sdf fs Envoy SLE
sdf 4.2L I6 2WD
Car just started running really Rough when I was driving it. (2002 Trailblazer 140,000 miles)
I changed all the plugs first (they were still the factory plugs) Then still had the same code. It said cyl. #6 missfire. I then changed the cold for that cyl.
Still get same code and it still runs like crap.
Anyhelp??????
Thanks so much!
Old 06-10-2008, 09:19 AM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Not sure what you mean by this.....
Old 06-10-2008, 09:56 AM
wbsterritt's Avatar
wbsterritt wbsterritt is offline
2003 Olds Bravada
Summit White 4.2L I6 AWD
what's the code?
What exactly is the DTC code that shows?
Old 06-10-2008, 10:21 AM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Anyhelp??????
Thanks so much!
Isn't P0302 cyl # 2? If nothing else just swap coils 2 and 1 and see if the code changes from one cyl to another.
Robert
Old 06-10-2008, 10:22 AM
petevw's Avatar
That's what I thought too
Old 06-10-2008, 07:42 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
P0302- Fault Cylinder B-Misfire Detected (CYL2). I agree with the replies above. try changing the coil for the Second Cylinder.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 06-12-2008, 12:00 PM
sdf fs Envoy SLE
sdf 4.2L I6 2WD
I meant coil sorry.
Also, it was code PO306 sorry again.
I was in a hurry typing this.
I think it might be a fuel injector.
Is there any information for a "how to" to change out an injector????
Old 06-12-2008, 12:01 PM
sdf fs Envoy SLE
sdf 4.2L I6 2WD
I did by a new coil and it still runs bad.
Old 06-13-2008, 01:51 AM
wardak33's Avatar
2002 Olds Bravada
Make sure that you're changing the coil for the right cylinder. a lot of people get the #1 and #6 cylinder's confused. if its still misfiring and shooting codes, then yea, it's most likely the fuel injector. i'm not really sure how to change that since i haven't done it before. but as a tip. every now and then run a bottle of techron. makes a BIG difference.
Old 06-13-2008, 07:58 AM
sdf fs Envoy SLE
sdf 4.2L I6 2WD
Autozone told me #6 was the one closest to the firewall. So thats the one I changed.
I did run techron through this 2 days ago, but never before that.
Any links to help me change the fuel injectors??
Similar Threads
Problems fixing rough idle - code P0300 grjoyner OEM Issues 16 02-06-2015 01:00 PM
How to change Spark Plugs on a 2004 TB with 4.2l keitho64 General 105 07-05-2011 01:59 AM
Changed out plugs...have new questions potts200 General 8 02-14-2007 09:39 PM
