Speaker Size (front and rear) - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-22-2008, 03:53 PM
onip28's Avatar
onip28 onip28 is offline
2003 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Hi,
I want to change out the speakers on the both sides of the front and rear. Does anyone know what size they are?
I'd open the door panels, but rather ask and then open them up to replace them in one time. Thanks to anyone who has input...
Steve
Old 06-22-2008, 04:07 PM
SteveTB03's Avatar
SteveTB03 SteveTB03 is offline
1998 JEEP ZJ
Spray Bomb Flat Black Other 4X4
I believe that they are 6 1/2" speakers front and rear
Old 06-22-2008, 05:28 PM
onip28's Avatar
Thanks a lot...If different, please advise...Thanks again though..
Old 06-22-2008, 06:26 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
some of us have had to fab up spacers to keep the magnets of the new speakers from hitting the door glass
Old 06-22-2008, 08:03 PM
seawolf06's Avatar
seawolf06 seawolf06 is offline
2007 Chevy TrailBlazer LT
Onyx Black 4.2L I6 4X4
What's the mounting depth of the speakers you installed? Crutchfield says 2" depth will fit, but I'm not sure that is the max.
Old 06-22-2008, 10:24 PM
MAY03LT's Avatar
TrailVoy Guru
They are 2.5" depth....when I got my speakers they checked out in the "will it fit" (that problem was corrected) even with a 1/2" spacer it is still really close
Old 06-22-2008, 11:46 PM
seawolf06's Avatar
So with just 2" of depth, I would be ok?
Old 06-23-2008, 10:25 AM
Aukland's Avatar
Aukland Aukland is offline
2002 GMC Envoy SLT
Rock-Chipped Burgundy 4.2L I6 4X4
Most speakers will work, Andrew(may03lt) has the Rockford Fosgate power component speakers. The others I know will not work are the yellow coned Pioneer's. If you are lookin at the fosgate punch, or anything to that caliber, you will be fine.
Tommy
Old 06-23-2008, 11:14 AM
mosssr33's Avatar
mosssr33 mosssr33 is offline
2003 Chevy TrailBlazer LT
Keep the old front housing, cut out the old tweeter and remove the 6 1/2". This makes a perfect bracket for a 6 1/2 component set. There is plenty of room to mount the crossover to the door panel. DO NOT PUT THE CROSSOVER IN THE BOTTOM OF THE DOOR FRAME! It looks like a great spot but all water from the window runs in that area. I have had to replace. I have pics.
For the back I used 5 1/4 coax. They dont fit in the bracket exactly but silicone around the speaker frame and the bracket for a good seal.
Old 06-23-2008, 02:16 PM
seawolf06's Avatar
Personally I would prefer to have the tweeters higher up.
I would either put them on the pillar where those two "plugs" are so that I don't have to cut or in the dash where the bose "tweeters" normally go.
Similar Threads
FINAL sway bar decision guide trailblazerdude Suspension 33 03-28-2016 05:19 PM
Ask: 245/65/17 front and 265/65/17 rear combination blackcool Tires 3 06-26-2008 06:26 PM
AIrcondition switch (front) controlling rear gixxer_751 General 3 05-27-2008 08:45 PM
Speaker size question Kirby Baker Audio and Electronics 17 10-12-2005 11:43 AM
Ordered My TB SS SS owner TrailBlazer SS Chat 39 10-04-2005 11:34 PM
