2006 TB fuel filter - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 07-08-2008, 08:13 PM
racermpn racermpn is offline
2006 Chevy TrailBlazer LS
Superior Blue Metallic 4.2L I6 2WD
2006 TB fuel filter
Is this true that the fuel filter is in the gas tank and cannot be replaced??
Old 07-08-2008, 08:15 PM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
It is in the gas tank. I assume you could replace it by dropping the tank.
BILL
Old 07-09-2008, 08:05 AM
TJay74 TJay74 is offline
2008 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 2WD
It is not a "filter" per say, more like a filter sock that sits on the end of the fuel pump.
They are not serviceable from what I have read and heard without replaceing the pump as the filter sock is not sold sperately.
2008 TBSS 3SS 2wd
HP Tuners, K&N CAI kit. Future mods:160 stat, UDP, Efans, resonator delete, and Magnaflow muffler.
Old 07-09-2008, 08:25 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Stick w/ top tier gasolines and you'll have nothing to worry about
-Mike
AKA PROVY
Rock On!
Old 07-09-2008, 10:20 AM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
All fuel pumps have a sock of some kind. I can't find a picture, but I gather that it's a regular-style fuel filter between the output of the pump and the top of the tank.
I do know that the fuel filter does not need to be replaced until the ~100-130k mark that the fuel pump needs replaced, because the fuel pump only pumps the amount of fuel that the engine needs, since it's a returnless system now. Before, the fuel filter actually filtered the fuel multiple times, especially a low throttle positions where the pump was pumping and the filter was filtering, say, 5x the fuel that the engine actually needed at that time.
Mike
Old 07-11-2008, 07:59 AM
I think the filter sock is the only thing, the GTO's ran into the same issue and when the pumps were pulled the sock filter was te only thing it the system when the pump was pulled.
Seems GM has done away with actual external tank filters anymore.
2008 TBSS 3SS 2wd
Old 07-11-2008, 08:13 AM
bartonmd's Avatar
So... is the sock made of the same material as normal filter material? There has to be a real filter, whatever the shape... Pretty much all fuel pumps in the tank have had sock strainers made of mesh, to stop objects big enough to damage the pump from getting in, so if this is true, they would have to have changed the sock to be a "real" filter...
mike
Old 07-13-2008, 06:08 PM
Nope no real filter anymore, just the same ole material that the socks have always been made of.
2008 TBSS 3SS 2wd
Old 07-14-2008, 08:00 AM
bartonmd's Avatar
In doing some more research, it seems that it is an actual "fuel filter" sock, not made out of the same plastic screen, though I have not had one in my hand, so I cannot say for myself.
Mike
Similar Threads
Clarification on Fuel Filter Change steviestyles General 27 04-02-2008 10:20 PM
Fuel filter ??? Bigchief OEM Issues 3 10-19-2007 03:36 PM
Fuel Filter ? Tpoppa General 6 10-04-2006 01:25 PM
Where is the fuel filter ? Lunchbox RR OEM Issues 11 09-20-2006 06:52 PM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
