P0014 error code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-09-2008, 09:59 AM
meierrh meierrh is offline
2006 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
Unhappy P0014 error code
Hello, Firstime poster here!
I have a 2006 Chevy Trailblazer V6 4wheel drive that has the engine light on. Took to Autozone and scan indicates P0014 possible faulty cam sensor. Can somebody explain to me exactly where this is located and how to determine if needing replacement? Noticed vehicle hesitates or vibrates a little at stops but only intermittently. Also noticed that it takes longer for transmission to downshift like when going up a hill. Any help would be apreciated.
Old 07-09-2008, 11:35 AM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Hello.
Welcome.
There are a few post on this P0014 code.
Once you hit 10 post you will be able to search.
But to get you started- look at this post with a pic of the part...
http://forums.trailvoy.com/showthrea...ighlight=P0014
Old 07-09-2008, 12:23 PM
Black 4.2L I6 4X4
Can you tell me where on the engine that I am supposed to find this. I have read some posts and it sounds like it is located below the power steering reservoir. Is this correct?
Old 07-09-2008, 01:39 PM
rbarrios's Avatar
TrailVoy Guru
Disregard what I said about the wrong info....
but heres a thread that may help you....
Old 07-27-2011, 08:19 PM
bwhitm bwhitm is offline
2002 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
P0014
Hey Guys Im new to the club and i have a 02 TB. The service engine light came on and the dreaded P0014 code came up. Its not running funny but it does tap a little. Any suggestions? Also for location follow this link:
http://forums.trailvoy.com/showthrea...shaft+actuator
Old 01-17-2015, 05:47 AM
Apple200 Apple200 is offline
2003 Olds Envoy SLT XL
Fire Red 4.2L I6 2WD
thank you for the info.
Similar Threads
P0014 Camshaft Position Actuator Help maddash32 Engine Tunes/Mods 25 06-15-2015 10:02 PM
Code P0014, tried to remove Cam Position sensor but PS fluid reservoir is in the way projectpete19 OEM Issues 46 03-22-2012 09:35 PM
P0105 and P0014 Codes! Cevy5454 OEM Issues 8 02-05-2008 04:00 PM
Code P0014 rbarrios OEM Issues 1 11-06-2007 04:05 PM
P0014 Camshaft Position Actuator B Need some assistance. 2manytoys OEM Issues 16 08-18-2007 08:22 PM
