Code P0140 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-09-2008, 05:05 PM
jdpap jdpap is offline
New Member
2005 GMC Envoy SLE
Magnetic Red Metallic 4.2L I6 2WD
Code P0140
My check engine light came on last week, went to Autozone, code P0140 came up. Says could be oxygen sensor, could be fuel pump, or engine misfiring. Has anyone else experienced this code or have any suggestions before I spend any money to let the dealer find the problem?
Thanks
Old 07-09-2008, 05:34 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
did a quick search for it on here... no results...
maybe one of the techs will chime in....
any chance it could be P0014?
Welcome!
Old 07-09-2008, 06:24 PM
New Member
2005 GMC Envoy SLE
No it is P0140.
Old 07-09-2008, 10:33 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
P0140- OXY SENS CIRC NO ACTIVITY DETECTED (BANK 1 SENS 2)
bad o2 sensor..check the wiring too..just in case.
(anyone correct me if i'm wrong)
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 07-11-2008, 03:46 AM
Audiojunky's Avatar
Audiojunky Audiojunky is offline
2005 Chevy TrailBlazer LS
Believe it or not, there is a fuse under the hood for the oxygen sensor, I'd check there first. Something could've nicked one of the wires and shorted it out.
Old 07-11-2008, 07:46 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
right on .... always connections first!
Bill
Let's get a Meet going!
Old 03-11-2009, 04:19 AM
chebbyfan chebbyfan is offline
2004 Chevy TrailBlazer LT
Two tone silverand white 4.2L I6 4X4
Code P0140
Okay my blazer KEEPS spitting out this code. I cleaned the throttle body and put some seafoam in the tank put the negative batttery terminal back on and drove it a liitle. Everything seems fine, except that it throws the code every other day. Only thing I did different, was replaced that lower one with battery still hooked up. Don't see how that would matter though. When mine says that it says something about heat malfunction though. Btw i replaced both sensors at the same time and only the lower one is giving me fits. The sensors are new Bosch.
Old 03-11-2009, 08:00 AM
Blazernut's Avatar
Check out this link
http://www.obd-codes.com/p0140
Lots of info and should be helpful. (It said not to copy the pages so I gave you the link instead)
Bill
Old 03-20-2011, 01:58 AM
RandyS RandyS is offline
Superior Blue Metallic 4.2L I6 4X4
P0140 code - books are wrong
I had been having a performance issue because the ignition timing would not go above 14 degrees. I recieved a P0140 on 2005 Chev Trailblazer LS 4.2L indicating a bad after-CAT O2 sensor. THE ODBII reader/monitor showed that the sensor reported values above 700 most of the time.
The Haynes book for the vehicle and also the Haynes book on ODB/ODBII both say that the computer uses the pre-CAT sensor to adjust timing and fuel, and that it does not use the after-CAT sensor for this. Incorrect! I replaced the only the after-CAT sensor (only change), and now the ignition timing works correctly and the vehicle performs well.
Similar Threads
Build Sheet lucaswhunter General 29 05-27-2012 01:42 PM
my build sheet 20ohfivetb General 0 06-01-2008 12:09 PM
Code cleared itself. Now time for inspection. bugeyed OEM Issues 0 12-09-2007 08:22 PM
Reduced Engine Power due to a P0128 code? onip28 OEM Issues 2 12-09-2007 03:02 AM
Cat is getting plugged AGAIN!! Bonez2 02-09 Vortec 4.2L I-6 Engine and Drivetrain 10 06-29-2007 03:40 PM
