Check Engine Light P1680 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-15-2008, 09:24 AM
camilosi's Avatar
camilosi camilosi is offline
2004 GMC Envoy SLE XUV
Hey Recently My Truck Had A Check Engine Light On It Came On On Saturday Afternoon With The Power Reduce Light Also I Hit The Gas And It Did Not Move Turn The Car Off And Back On And I Was Able To Get Going Light Remain On That Day And Sunday Then Sunday Night Light Turn Off I Check The Code On Monday With A Match Scanner And Pulled P1680 The Light Is Not On But I Was Checking And Found Some Website That States There Is A Tsb Available For This Code And That There Might B A Warranty Up 80k Miles.have U Guys Heard About This And Do U Guys Know About This Code.
Old 07-15-2008, 10:20 AM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
I found this on an other site:
you have to reprogramm the ecm.here is a bulletin for this problem.Subject: Service Engine Soon Light On, P1680 (Reprogram or Replace PCM)
________________________________________
Models: 2004 Buick Rainier
2004 Chevrolet Trailblazer
2004 GMC Envoy
2004 Oldsmobile Bravada
with 4.2L Engine (VIN S - RPO LL8)
Some customers may comment on the Service Engine Soon Light coming on. Upon investigation, the technician may find a P1680 diagnostic trouble codeCheck the resistance of the accelerator pedal position sensors using the procedure in the appropriate Service Information for DTC P1680.
If the resistance of the accelerator pedal position sensor is within the specifications shown in the Service Information and the vehicle was built prior to the following VIN breakpoints, then reprogram the PCM with the latest calibration.
If the resistance of the accelerator pedal position sensor is within the specifications shown in the Service Information and the vehicle was built after the following VIN breakpoints, then replace the PCM. If the resistance of the accelerator pedal position sensor is outside the specifications shown in the Service Information, then continue with the diagnostics for DTC P1680.
__________________________________________
Here is the site: http://www.2carpros.com/forum/2004-g...-vt118343.html
You might fix it with a need PCM flash (a new flash will provide needed updates anyway), but if PCM needs to be replaced, it should be free under the emissions warranty
Ray
Old 09-16-2010, 09:11 AM
Cody_S's Avatar
Cody_S Cody_S is offline
2004 GMC Envoy SLT
Onyx Black 4.2L I6 2WD
hm, maybe that's why my check engine light keeps coming on. It'll stay on for a bit, then when I'm about to go check it, it goes off for like a week or two, then comes back on for like a couple days. Haven't noticed any problems though.
Cody
South East Chapter Member - Georgia
Old 03-13-2011, 11:18 AM
Paidfor04 Paidfor04 is offline
2004 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Code P1680
I had the same thing happen to my 04 yesterday. Pulled a P1680 code. I think my Trailblazer falls under a service bulletin for a PCM reflash for this problem. Hopefully clears up some mild drivability issues (sluggish) I've been having!
Old 05-19-2011, 10:57 AM
leeraymond leeraymond is offline
Graystone Metallic 4.2L I6 2WD
I also got the P1680 code, I cleaned the thottle body like the dealer said to, well I was also today to change the APP sensor from a co-worker, and also to reprogram the computer, but how do you know i need to reprogram it???
Old 09-23-2011, 07:49 PM
karla0421 karla0421 is offline
silver 4.2L I6 2WD
Check Engine and Reduce Engine Light came on
Hello everybody,
I really need somebody's help. Ive owned a trailblazer 04 for the past 7 months. Sometimes when waiting on a light and when trying to accelerate it will seem like it wants to turn off. When I stop again the service engine soon comes on and the reduce engine comes on. At the moment I can be pressing the pedal and it doesnt move. It moves but slowly. I turned my car off and then turned it bavk on and then it starts running okay. But with the engine light on.
I went to autozone to get it checked and the gave me the P1680 code and the guy tells me I have to buy a new computer for the vehicle. Can somebody tell me what to do? This is the only car I depend on.
Old 11-15-2011, 05:23 PM
sunnytb sunnytb is offline
2004 Chevy TrailBlazer LT
Graphite Metallic 4.2L I6 2WD
Follow up - P1680
I'm having the same issues with my '04 TB. Taking it in for reprogamming of PCM this week. I was just wondering if the reprogramming and/or replacing with a preformancePCM has resolved the problems for those who have posted on this thread.
Thanks!!
Old 01-17-2015, 05:47 AM
Apple200 Apple200 is offline
2003 Olds Envoy SLT XL
Fire Red 4.2L I6 2WD
Interesting read. Thanks for the share.
Similar Threads
Envoy 4.2 Vortec 2002. Aftermarket CAT= Check engine light phatz OEM Issues 1 05-18-2008 11:08 AM
Check Engine Light OKC_BOI OEM Issues 5 01-19-2008 08:13 PM
Check Engine Light...problems with dealer gordinho80 OEM Issues 10 07-11-2006 11:37 PM
Reset Engine Check Light? dbru899271 02-09 Vortec 4.2L I-6 Engine and Drivetrain 4 04-14-2006 04:16 PM
check engine light and change oil light phatmike OEM Issues 2 04-01-2006 06:56 AM
