Engine stalls when A/C is turned on. 04' Envoy - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-19-2008, 05:10 PM
oORipMaOo's Avatar
oORipMaOo oORipMaOo is offline
2004 GMC Envoy SLE
Summit White 4.2L I6 AWD
I just put in a brand new DieHard battery in my 04' Envoy and every since then when I turn on the A/C , my engine stalls or shut off. When A/C is off, engine runs fine. I put gauges on the system to see if it needed freon and freon level is good. Compressor runs perfect when you first start up the engine. After you press the gas, the problem starts. Pretty weird. Can anyone help?
Old 07-19-2008, 09:12 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
this is a very easy fix. it will cost you about $5 and take about 45 min.
the key points here are---- changed the battery, engine stalls with AC ON, engine runs fine with AC off.
You simply have a dirty throttle body..... and with the battery disconnect- theres some learned settings that have been lost.
Buy a can of throttle body cleaner.
now you have 2 options....
you can either do a thougrough cleaning- or you can do a semi clean.
(I have 127,500 miles and all my cleanings have been semi). meaning that I leave the TB on- but spray the cleaner in- and move the plate back and forth to dislodge the accumulated crud. either way- is your choice....
But when you clean it- disconnect the battery for at least 30 min... so that it loses any bad learned settings.
what you want is for it to relearn with a clean TB.
heres the how to
http://forums.trailvoy.com/articles....ticle&artid=91
Old 07-20-2008, 12:05 AM
oORipMaOo's Avatar
2004 GMC Envoy SLE
Good looking for replying back to my problem. I will be on it first thing in the morning. I really hope this works. I hate riding with my windows down, especially in the summer.
Old 07-20-2008, 02:02 AM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
don't worry. almost 99% of the time, the case is a dirty TB. and whats wrong with the windows down?! feel the breeze man. look good!!
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 07-20-2008, 05:28 PM
oORipMaOo's Avatar
2004 GMC Envoy SLE
lol! Well right now I have no choice.
Old 07-21-2008, 01:11 PM
oORipMaOo's Avatar
2004 GMC Envoy SLE
So far so good. I dont wanna get my hopes up yet. I'll wait a day. But my throttle body looks brand new now after cleaning it. If the problem starts again I still appreciate the help. Peace out!
Old 07-21-2008, 02:42 PM
rbarrios's Avatar
TrailVoy Guru
keep us updated.
Old 07-23-2008, 12:51 PM
oORipMaOo's Avatar
2004 GMC Envoy SLE
thanx alot guys, that was definetly it. its been perfect for the past 2 days. i have 53,000 miles on it. is there anything that i should change or look at?
Old 07-23-2008, 02:38 PM
rbarrios's Avatar
TrailVoy Guru
If I could go back in time--- I would change out the tranny fluid at 50,000.
Old 05-01-2011, 09:27 PM
rockytop rockytop is offline
2002 GMC Envoy SLT XL
Summit White 4.2L I6 4X4
2002 envoy 4.2l i-6 a/c on dies
all ran fine i unhooked the battery when i hooked up wife drove and it would die come to find out it only done it under stress a/c on or sharp turn first just unhooked battery then hooked up drove with a/c off 10 miles to get intake cleaner when got home turned a/c on it worked thought i would clean it any way then unhooked battery waited 10 min hooked battery up and drove this time had a/c on. it was back to not working.guess question when hook up battery should i drive for awile with a/c off then turn it on since it seemed to work the first time or was it just a freak accident i want to fix this my self i have had issues in past and its 300 a pop dont want to pay that.this envoy has had sincer problems 3 times in past got 160.000 miles
