If you regularly need to go across rock gaps, shelves, or stairsteps that could swallow your tires, destroy your rocker panels, or hang up your bumpers, you might be in the market for what the expeditionists call Bridging Ladders. $450-500 a pair.
In aluminum, about 20 pounds each.
If all you need is something to throw under your tires if stuck in sand or mud, then use Sand Ladders at $200-250 a pair:
All proper desert-outfitted Camel Trophy Land Rovers have these as part of the kit:
But if you're a bit more frugal like me, and looking for the most modern (and recycled) multi-purpose stuff, you should be looking at a set of fiberglass/resin bridging ladders. One vehicle in a group should have these, and in my group of usually one vehicle, I guess that's me.
Seller:
Norman Klapper
info@pecboulder.com
Ebay vendor: infopec
2" FIBERGLASS MOLDED GRATING, VINYLESTER RESIN
Current Ebay listing: 120286393067 (will change)
Current description:
TRACK PADS & BRIDGING LADDERS - OFF-ROAD USE /12" x 48"
12" x 48" PAIR OF TWO (2)
$96.00 plus shipping
18 pounds each - shipping weight for 2 about 40 pounds from Colorado.
Note minor deflection - was accompanied by minor creaking noises.
After taking the Envoy off 'em, they came back exactly to flat again. I would have no hesitation to use these on a trail I had to use them to get OFF of later. Highly recommended!
