MAP Sensor Cleaning - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-12-2008, 12:33 PM
02NYenvoy's Avatar
02NYenvoy 02NYenvoy is offline
2002 GMC Envoy SLT
Black 4.2L I6 4X4
MAP Sensor Cleaning
I am in the process of tracking down a slight hesitation problem. Noticed that the MAP sensor has oil from the drop-in K&N filter. What's the safest way to clean the sensor?
02 Envoy SLT 123k
Old 08-13-2008, 01:02 AM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
i had an attempt to clean in too, but someone on automotiveforums.com stated that the MAP sensor is a closed sensor and cannot be cleaned...i'm still going to give it a try though. When you do clean it, make sure you use MAF/MAP Cleaner and make sure its completely dry before putting it back in.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 10-18-2009, 06:41 PM
cgallo cgallo is offline
2003 Chevy TrailBlazer LTZ
Liquid Silver Metallic 4.2L I6 4X4
Today, I cleaned MAP sensor, carefully, I Unplug from the Intake, specially with the 2 Plastic Brackets Of the Body of the Sensor, I Cleaned with Electronic Contact Cleaner inside the Little Hole and Shook until no liquid go out from it.
I conect it to the Intake and run the car, It runs fine.
I did do tracking down a better milleage, I cleaned the IAT Too.
Cesar Gallo
Old 09-27-2013, 11:29 AM
Tainstve Tainstve is offline
qwerty qwerty qwerty
qwerty 6.0L LS2 V8 2WD
This post is*very*informative.*Thank you!
