Body Control Module - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-13-2008, 06:29 PM
W3RD W3RD is offline
Envoy SLT GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
Body Control Module
I have a good idea that my BCM is gone seeing as my memory controls on my 2002 Envoy SLT are basically gone, but my rear window wiper has gone on the fritz. It works fine but its reacts to the bass my subs create, i think its the motor, i disconnected it and it stoped doing it but does anybody have anyother ideas?
Old 08-13-2008, 07:02 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
We might need more info.
The radio presets are controlled by the radio computer.
You have the auto HVAC and the mem preset for it are controlled by the HVAC computer.
The power seat memory is controlled by the door computer (I think).
The lock/unlock memory is controlled by the liftgate computer.
These all talk to the BCM, but I don't think the BCM keeps the preset info.
The rear wiper, different problem maybe. Perhaps all problems have something to do with the amp
Ray
Old 08-13-2008, 07:05 PM
hatchet669's Avatar
hatchet669 hatchet669 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
try disconnecting the battery for a half hour... someone had a problem like that and they reset all the computers by disconnecting the battery and all was well... hey its worth a shot and its free..
Old 08-13-2008, 07:08 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Ray
Old 08-13-2008, 07:14 PM
91RS 91RS is offline
If it is indeed a module problem, it's the liftgate control module. That module controls the rear wiper and is the reciever for the key fobs so it could affect your memory settings if it doesn't communicate to the truck which fob is being used (driver 1 or 2). You're best bet is to take it to the dealer to get it properly diagnosed, it is nearly impossible to tell you what's wrong without actually seeing what's going on with the truck with a Tech 2. However, I will say it isn't uncommon to have a BCM go bad in these trucks. I had to replace mine because the auto headlights weren't working and it wouldn't turn off the interior lights if the doors were left open, and I also fried the rest of it installing my amp.
Old 06-02-2009, 07:15 PM
CSI CSI is offline
Body control module
I have a 2002 trailblazer and am trying to replace the body control module. The problem is i can not find out where it is located in the trailblazer. Can anyone help me out?
Old 06-02-2009, 08:16 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
It is part of the rear seat fuse panel, hmmm, or is the fuse panel part of the BCM. I suspect they are an integral assembly.
Ray
Old 02-26-2010, 03:45 PM
iznit's Avatar
iznit iznit is offline
2002 Chevy TrailBlazer LS
I know this is an old thread but I haven't found any with a solution to the problem. When my bass hits hard my rear wiper engages and proceeds to wipe across the window. Depending on how hard the bass is hitting the wiper might wipe about 1/4th of the way if it's not too bad. If it's really hard it will go all the way. It's pretty annoying so I disconnected the rear wiper all together. Anyone have any ideas or solutions besides turning the bass down?
I'm running to 12" Kicker L7's in a custom ported box off of a Kicker XS100 amp.
Old 02-26-2010, 08:08 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Could be a ground problem, these trucks have a lot of ground points and one or more might be dirty.
But, I'm leaning to a simple induction problem. You might solve the problem by moving the amp/speaker wires.
Ray
Old 03-12-2014, 09:26 AM
Speedbump Speedbump is offline
2004 Trailblazer TrailBlazer LT
I have 2004 trailblazer that when you take key out the security light and service engine light stays on and the throttllemotor cylcles and kills the batt. Hit the break pedal and the lights go out! Release pedal they come back on! Any ideas?
