HELP!!! No crank ignition issue!!! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-25-2008, 10:54 PM
Doc Doc is offline
New Member
OK guys, here is the story. My wife went out the other night to roll the windows down on our 2003 trailblazer (6 cylinder), and left the key in the run position over night. Next morning I went to start the truck and well......dead battery. Charged it and tried to start the truck.....nothing. I have replaced the battery, ignition switch, checked the starter relay and double checked every fuse in both boxes. It's not the starter because I can jump the starter with a screw driver and make the engine turn over. Everything works inside the truck and all the lights come on just fine. I am stumped. Any suggestions??????
Old 08-25-2008, 11:33 PM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Does it have the battery run down protection?
Brendan,
PCMFORLESS Tune, CAI, HID's, PIAA's, Mirror Signals, Glasspack & Tip
Old 08-26-2008, 11:30 AM
neelskit's Avatar
neelskit neelskit is offline
2002 Chevy TrailBlazer LT EXT
Pewter Metallic 4.2L I6 4X4
Does the security light on the dash flash when you turn the key to start?
Old 08-26-2008, 04:43 PM
Doc Doc is offline
New Member
Yes, the secuity light flashes a few times when the key is turned to the on position and then it stays on.
Does anyone out there with a service manual know what the security module reset procedure is? I know it is something like turn the key on and wait 'till the security light turns off, then turn the key off for a minute and repeate the procedure 2 more times but I would like to see the actual procedure. I don't know if the key has to be turned to the crank position first and then to the on position or if there are other details I don't know about. Thanks again for the help.
Old 08-27-2008, 08:45 AM
neelskit's Avatar
I know that some people have had to do a security re-learn after getting a tuned PCM. I've seen the procedure on here before...
Here it is:
http://forums.trailvoy.com/showpost....3&postcount=24
This should get you back up and running.
Old 08-27-2008, 08:44 PM
Doc Doc is offline
New Member
Neelskit,
Thanks for the link. I was able to talk to a mechanic that was nice enough to give me the reset procedure last night and that did the trick. The procedure he gave me is the same procedure that was in the link so that is definetly the right steps to reset it. I am still a little puzzled as to why leaving the key in the on position would have caused my issue but I guess I will get over it since I have a running truck now!!
Old 08-29-2008, 03:15 PM
neelskit's Avatar
No prob!
The electronics on these trucks can be stubborn at times. In your case, probably just a glitch.
Glad your driving again!
Old 11-05-2008, 10:19 PM
KrazyRat KrazyRat is offline
Graphite Metallic 4.2L I6 4X4
start issue
I'm having a no start problem, I've gone through the threads with no avail. My shifter is NOT getting stuck at all and it has free range. That is why I want to rule out the ignition switch. I turn the key and nothing happens, if I jiggle the shifter around while attempting to start it, sometimes it works. I started with the cheap end of it and replaced my park/nutural safety switch, it was only 34.99. It seemed to be fine and I thought I was out of the woods until it happened to me again twice today. So I go through the normal routine of shifter jiggle and turning it over and I finally get it to start. This may sound weird but it seems to only occur when it is cold. Please help me!
Old 12-25-2012, 09:55 AM
Trchamp Trchamp is offline
Trailblazer Chevy TrailBlazer LT
Did you ever find out what is wrong? I am having the same problem.
Old 06-26-2015, 03:56 PM
Fixrguy Fixrguy is offline
2002 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
I have the same issue from time to time, just yesterday I had to do the relearn. It does work, but where does the memory live? In the BCM? Over the last 2-3 years I've done it 5-6 times. If I could nail it down to a bad BCM or ECM I'd be well on my way to a more reliable truck.
Tags
not starting, unknown driver
