[SOLVED] Idle air control - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-11-2008, 11:30 AM
meltdawg's Avatar
meltdawg meltdawg is offline
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
Idle air control
First of all hello to all trailvoy enthusiast, i encountered a problem this weekend with my air conditioner. Every time i engage my a/c my trailblazer starts to die out and sometimes does shut off but works fine when a/c is not on. So i ask a friend for the solution and he says it's my IAC and he says it needs to be replaced or cleaned, i never did ask how to clean the IAC. So if anyone has been in this situation and has cleaned their IAC please reply and any suggestions is welcome. I called the dealer to see if it was a valve part to be replaced but i was told it is part of the throttle body and costs 300.00 dollars. I'd like to make this my project today, thanks to all.
Old 09-11-2008, 02:13 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Did you recently have the battery disconnected for any reason? This is a common problem many people have encountered here.
What happens is most likely your throttle body is dirty. The computer learns to compensate for the dirty throttle body and adjusts accordingly. If you disconnect your battery it "forgets" what it learned and goes back to factory settings.
Here is one of many posts about the subject:
http://forums.trailvoy.com/showthrea...hrottle+bod y
Good luck!
Old 09-11-2008, 02:16 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Idle air control is done with the throttle body, there is no separate IAC valve on these. So most likely you need to clean it. Considering you have an '03, it is probably past due for a cleaning. Here's a good article how-to:
http://forums.trailvoy.com/articles....ticle&artid=91
Old 09-11-2008, 04:03 PM
meltdawg's Avatar
Thanks guys for the info. I purchased a throttle body cleaner and tackled the project and in no time was done, and guess what it was dirty and gunky. After i cleaned it, fired it up and it idled just like new and ran even better it seems. I would like to thank you all and i appreciate this site for all it does for all trailvoy owners. Peace
Old 08-29-2009, 11:50 AM
bert19 bert19 is offline
2004 GMC Envoy SLT XL
It works!
I was having similar problems with the idle air control and throttle body and after cleaning it thoroughly, the problem was remedied. Thanks for the info.
Old 04-14-2010, 08:50 PM
blazer69 blazer69 is offline
2002 Chevy TrailBlazer LT
Pewter Metallic 4.2L I6 2WD
Thanks a bunch!
Wow! I joined this forum after finding the same symptoms I was experiencing with my '02 TB 2wd, to get the remedy. Cleaned the throttle body with SeaFoam...idles like a champ now with a/c wide open! Can't thank you guys enough. I really appreciate it. Also, I've got a tip for anyone having issues with their driver side door master switch that could save you a lot of cash. Just had to solve that one on my own.
Old 06-03-2010, 12:46 PM
thefueley thefueley is offline
Forest Green Metallic 4.2L I6 2WD
Great info!
Thanks for the post. I am experiencing similiar issues when I turn on the A/C or heater. I have to keep the gas pressed a little to prevent stalling. I read the links that describe how to clean the throttle body. I do have a question though. On one of them, the one without the pictures, someone mentions to NOT open the valve with your fingers while cleaning it. It mentions that one should clean in front and behind but not to operate the valve with your fingers. Since this is about a $300 part. I'd like to be sure before I attemtpt this. Thanks for the info. I plan on doing this this weekend.
Old 06-03-2010, 12:51 PM
Topher's Avatar
Topher Topher is offline
2002 GMC Envoy SLT
The reason you shouldn't use your fingers is that the plate in the valve is very sharp. If you use your fingers it's easy to get a bad cut. I usually use a wad of paper towels and hold the valve open to clean it as thoroughly as possible.
200k miles and counting
Fullly stocked with Amsoil; Quad headlight mod; Jetttstream quad LED brakelights.
Old 06-03-2010, 09:29 PM
Brian K Brian K is offline
2009 GMC Envoy SLT
Black 4.2L I6 4X4
I cleaned my throttle body today too (and in my Chrys 300 and Lincoln MKX). Dead easy and no problem with cycling it open and closed. I disconnected the battery negative and took off the electrical connector (gently). I used a screw driver with a rubber handle (used the rubber handle part) to hold the disk open so the cleaner would work and clean the edges. My Envoy only had 30k kilometers on it but was still kind of dirty. Wasn't experienced any idle issues - but a bit of prevention...Great site to learn these easy to do PM things to keep the vehicle working in top condition. will be taking it on a 6 hour drive tomorrow so will see if mileage improves - I hope so.
Old 07-18-2010, 07:46 PM
add925a add925a is offline
Trailblazer Chevy TrailBlazer LT
Black Granite Metallic 4.2L I6 4X4
It worked!
Wonderful article, thanks. This absolutely fixed my AC/idle problem, just as you suggested. Thanks again!
