Rear caliper bolts - HOW TO GET THEM OFF?!!? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 09-20-2008, 01:37 PM
JeremyM JeremyM is offline
2005 Chevy TrailBlazer LS
I've read that people use breaker bars and heat the bolts up. I have no way to heat them so where the hell do you fit a breaker bar in there? It's so tight, even with the main caliper off and the pads out. I broke an impact socket on the bolt it's so tight.
Is there some sort of loctiteish solution on these bolts causing them to be so hard to remove or is it just from rust/not being touched for 50 thousand miles?
Old 09-20-2008, 01:48 PM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Every GM truck is like that. A snipe or breaker bar is pretty much the only way. Heat helps alot too if available.
Good Luck
Brendan,
PCMFORLESS Tune, CAI, HID's, PIAA's, Mirror Signals, Glasspack & Tip
Old 09-20-2008, 02:57 PM
justblazin's Avatar
justblazin justblazin is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Do you mean Caliper bolts or Caliper Bracket bolts??
MY Caliper bolts came off easy with the help of 2 wrenches. One to hold the pin steady, the other to lossen the bolt. As for the Brackets, Mine where on tight.. I used a 18mm wrench and a 3lbs sledge. Put the wrench on and hit it with the sledge. Came loose after 2 hits. GM uses a crap load of locktite on the bracket bolts.
4 little words to swear buy - BUY THE WIRE HARNESS!!!!
Mid-Atlantic Chapter Member
Old 09-20-2008, 03:34 PM
bentcougar's Avatar
bentcougar bentcougar is offline
2007 Chevy TrailBlazer LS
Onyx Black 4.2L I6 4X4
Midwest Chapter KS Rep
Old 09-20-2008, 05:08 PM
I broke a damn impact socket (18mm) on the first one I tried. I ended up putting all the old stuff back on and just am going to get it done. I could NOT get it off, I even tried rust eater and stuff on it.
I hate to give up...but, I just couldn't free the ****ers.
I had a 5 pound sledge and a breaker ratchet.
Old 09-20-2008, 05:39 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
What I sometimes do is, using a ratcheted socket, slide the ratchet onto the bolt and bring it do to where it's almost horizontal, then I wedged a bat between the chassis and over the ratchet and pushed down on it
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
