Fan switch for Heater/AC only works on 3 -5 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-03-2008, 12:53 PM
MCunningham MCunningham is offline
2004 Chevy TrailBlazer LS
I think the fan switch on my 04 TB is gone. The blower only works on 3 thru 5 and the location switch/Defrost/Upper/Lower/ is like it will only work of I turn it very slowly, If I turn from one extreme to the other. It stays on the first setting.
Not sure what it could be?
Help. Winter is coming!!!!!!!!
Old 10-03-2008, 02:38 PM
Ray Dockrey's Avatar
Ray Dockrey Ray Dockrey is offline
2009 Chrysler PT Cruiser
Inferno Red Other 2WD
The fan speed issue is caused by the blower moter resistor. Your other issue is the mode door actuator. Both are very common issues.
Here is for the resistor:
http://forums.trailvoy.com/showthrea...light=resistor
Here is for the mode door actuator:
http://forums.trailvoy.com/showthrea...light=actuator
Old 10-03-2008, 03:25 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
happens all the time. just curious, but do you have the digital climate control?
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 10-03-2008, 05:39 PM
04 TB with manual control
I have an 04 with the manual control...
Old 10-03-2008, 05:42 PM
Fan speed issue
Thanks for the links with the pictures. It will be a lot easier then doing it blind.
