Check Engine Light - Cylinder Misfire - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-07-2008, 04:25 PM
markdjr markdjr is offline
LS Chevy TrailBlazer LS
I am getting error code P0300 on my 05 I6 Trailblazer. I am replacing all the spark plugs right now, but I noticed they have some oil on the threads which Im not sure is a good thing, and also there was some moisture in cylinder 4 where I took the coil pack out, as well as inside the little rubber spring thing between the coil and plug. Any ideas? Thanks.
Old 10-07-2008, 04:50 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
A little oil on the plugs is normal. after putting on some miles, oil seeps through, so i wouldn't worry much about it. as for the moisture in your #4 cylinder, there is a TSB regarding that problem, and the dealer should be able to fix it for you. Supposedly the seal isn't tight enough to keep water out when it rains? I'll try to find the thread that explains in in the mean time. Just curious, but how many miles do you have?
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 10-07-2008, 04:55 PM
wardak33's Avatar
2002 Olds Bravada
EDIT: reposted twice...sorry
Old 10-07-2008, 05:48 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
wardak is right on...
when it rains- the water gets past the seal on the hood and lands on top of the engine around cylinder # 4. it finds its way into the plug hole- and causes misfires....
yes oil in the holes is also normal after some miles.
Old 10-08-2008, 12:47 PM
Ive got 62k miles. Is there a trick to replacing spark plugs 5 and 6? I have gotten 1-4 and still have check engine light.
Old 10-08-2008, 01:00 PM
rbarrios's Avatar
TrailVoy Guru
no trick. youll have to have the right lenght extension for the # 6....
but I actually found that #1 was harder to remove- than #6.
just stand on a small ladder or box to reach #6.
Old 10-14-2008, 01:29 PM
the_dc_skater06's Avatar
the_dc_skater06 the_dc_skater06 is offline
2002 Chevy TrailBlazer LS
has this problem been resolved yet?
