Hi my car shuts off while driving - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 10-09-2008, 01:58 AM
rafaguero rafaguero is offline
New Member
2005 Isuzu Ascender
Summit White 4.2L I6 2WD
Hi, my car some times shuts off while driving. Then I start it and runs fine. In addition some times when I start it, it starts on the second try. Does any body have any idea of what could be causing the problem?
Thanks for your help.
Old 10-09-2008, 09:02 AM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
Possible ignition switch problem.
BILL
Old 10-09-2008, 11:19 AM
New Member
2005 Isuzu Ascender
I will check it out and let you know what I find.
thanks.
Old 10-09-2008, 01:42 PM
DJDarknez DJDarknez is offline
Senior Member
2009 Non-GMT360 Other
Black Other AWD
What year do you have? That would happen occasionally to me on my 2004. The dealer ended up re-flashing the PCM and that fixed the problem.
Old 10-09-2008, 02:02 PM
New Member
2005 Isuzu Ascender
I actually have an isuzu ascender 2005 which is the same as the trailblazer. What was the cost for flushing the PCM?
Old 10-09-2008, 02:40 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
flashing the PCM = flashing the Powertrain Control Module....
meaning they reload the software....
flushing would mean theyre getting rid of some liquid.....
But- when youre driving- and it shuts off... how fast are you going?
if youre going slow 0-15 mph?- and making a turn or something--- is this when it turns off? or are you going 55-70 and it turns off?
Old 10-09-2008, 02:45 PM
New Member
2005 Isuzu Ascender
it turns off when I am slowing down and it does not happen all the time. Once in a while, more like every other day once a day.
Old 10-09-2008, 02:54 PM
Irish2685's Avatar
Irish2685 Irish2685 is offline
2003 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
I'm thinking ignition switch. This happened to my g/f's Alero once in a while. She got the ignition switch fixed, and that solved the problem. But, the fact that it happens when you are slowing makes me think a loose connection somewhere.
Old 10-09-2008, 03:02 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
also, inspect the battery cables/ terminals....intermittent stalling was one of the symptoms my tb had when it had a poor connection at the battery
Old 10-11-2008, 05:20 AM
ltdakheel's Avatar
ltdakheel ltdakheel is offline
2007 GMC Envoy Denali
Liquid Silver Metallic 5.3L V8 4X4
if its shut off when take you foot off padel to slow down , i recommand you to chechk the throttle body switch my the problem , because when take your foot off throttle body should not close its should open by 10% to allow more , check the chouk as well , does you car have wire padel or electric TB
475 HP @ 10psi
P1-SC1,dual interceptor guages,dewitts C5efans,TRANS COOLER,ARheaders,methanol injection,LS2 TB,cutout
