| OEM Issues Original Equipment Repairs and/or Problems |
10-13-2008, 03:47 PM
2003 Chevy TrailBlazer LT Pewter Metallic 4.2L I6 4X4
Idle high/ Cleaning throttle body
My 03 Trailblazer I6 seems to hang the idle up about 1500 rpms then comes down. I've cleaned the throttle body. Is there an IAC motor that controls the idle. I can feel it hang up with my foot off the gas and it seems to be going by itself while in drive. I shift into neutral and the idle hangs up at 1500 then takes its time coming back down. Any suggestions?
10-13-2008, 08:40 PM
2002 Olds Bravada Pewter Metallic 4.2L I6 AWD
did you disconnect the battery while you were cleaning it?
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
10-13-2008, 09:39 PM
2005 Chevy TrailBlazer LT Dark Gray Metallic 4.2L I6 4X4
There is a stepper motor.
10-14-2008, 02:23 AM
No, I did not disconnect the battery while cleaning it. The idle problem existed before I cleaned it.
10-14-2008, 07:02 AM
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __ sExY Dark Gray Metalic 4.2L I6 4X4
The battery must be disconnected in order to reset the PCM.
Hopefully you removed the throttle body for the cleaning process in order to get the backside of the throttle plate 100% clean.
Bill
trailvoy.com
Let's get a Meet going!
10-14-2008, 01:36 PM
TrailVoy Guru
2003 Chevy TrailBlazer LS Pewter Metallic 4.2L I6 2WD
hopefully you also cleaned the throttle body with the KEYS OFF (ignition not on).
these stepper motors do not like to be moved when power is applied-
you can damage it.
the stepper motors circuit senses the movement youre giving it- and tries to counteract it--- if you force it-- damage can occur.
So thats why its recommended that you leave the keys out of the ignition- (since many people want to turn on their radio)...
and so disconnecting the battery for 30+ minutes also clears memory and throttle body can relearn new parameters with clean throttle body.
10-14-2008, 05:10 PM
2003 Chevy TrailBlazer LT Emerald Jewel Metallic 4.2L I6 2WD
I was told by a member that to reset the idle you should disconnect the battery for 30 min, reconnect and start the engine with out touching the accelerator until it idle at around 600rpms, then turn it off, for the next start is should be working Ok.
Hope it works for you!
Bilstein HD, K&N CAI 57 with gutted air box, Alpine IVA-W205 HU GT5-4.10 gears G80, 6000°K HID Lows and Fog, PCMForLess,
10-14-2008, 05:49 PM
 disconnect the battery for about 30 minutes to an hour and see if it helps. it should.
10-14-2008, 10:03 PM
2004 Chevy TrailBlazer LS Summit White 4.2L I6 2WD
Disconnect the battery, THEN REMOVE the throttle body, THEN clean it. I started by just cleaning the throttle body with it on the truck, then I decided to just remove it and clean everything. I MISSED SOOO MUCH when cleaning it on the truck, plus I noticed that I pushed a lot of dirt thru the throttle body into intake manifold. I'm so glade I caught that!!! I almost maid things so much worse.
10-15-2008, 11:59 AM
2008 Chevy TrailBlazer LT Dk Brahma Jewel Metallic 4.2L I6 2WD
Disconnect the battery, mine did the exact same thing when I removed the TB to clean. I disconnected the battery for a bit, reconnected and blango all better.
| Sponsored Links |
You may not post new threads
You may not post replies
