Anti-Lock brake issue - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 10-16-2008, 04:12 PM
DRock24 DRock24 is offline
2002 Chevy TrailBlazer LT
Graphite Metallic 4.2L I6 4X4
Hello, I have recently been experiencing a problem with the anti-ock brakes on my 2002 trailbazer LT. The brakes work fine when you initially press them, but as the vehicle is coming to a complete stop, and only withn the vehicle is rolling to a stop (right as the vehicle is about to completely stop), the anti-lock brakes kick in. No ice, rain, etc...normal temp and normal pavement. Anyone have any ideas?
Old 10-16-2008, 04:43 PM
bigbadbowtie088's Avatar
bigbadbowtie088 bigbadbowtie088 is offline
2005 Chevy TrailBlazer LS
Baja Black 4.2L I6 2WD
I had my truck in the shop and they replaced the hub assembly and the problem went away. It was exactly as you described it.
by the way Welcome to Trailvoy. make sure to fill out your profile so we know more about you and your truck.
Old 10-16-2008, 05:23 PM
That would be odd b/c I just replaced the hub assembly on the drivers side approx. 5000 miles ago Cost me an arm and a leg. I sure hope that not the case. Any other ideas? Thanks a million.
Old 10-16-2008, 08:10 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
replace the wheel hubs and installing the ssbc braking kit. problem solved too!
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
Old 10-16-2008, 08:54 PM
anyway I could just turn the ABS off??? Or should I not do that? Thanks
Old 10-16-2008, 11:54 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
I do not think that you can do that.
Robert
Old 10-17-2008, 05:40 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Could be a wheel speed sensor gone bad. It thinks one wheel is locked up and the other one is still turning = detects one wheel lock-up and initiates pulsing.
Bill
Let's get a Meet going!
Old 10-17-2008, 06:31 AM
vinman's Avatar
vinman vinman is offline
2003 Olds Bravada
Artic White 4.2L I6 AWD
my friend had a similar issue w/ his 02 tb. It would really kick in if you were stopping, and hit a bump. Turns out, a few months after noticing that, the wheel bearing went. Maybe its the sensor on the side you didn't get replaced?
If you have air tools and some mechanical ablity, you should do the hub yourself..and save some bucks (the only expensive part would be the hub)..
all you need is a 35mm axle nut socket (can get at autozone and Im sure other places) and a 19mm/18mm to take the caliper off and to get the three bolts that hold the hub, and I think thats pretty much it. (though I'm sure I'm missing something)
Old 10-31-2008, 03:26 PM
ok, this is what i did. I pulled the fuse on the anti lock brakes and the problem went away. Now i do not have any anti lock brake but that does not bother me. am I causing any other problems to my vehicle by doing this or will everything be ok? thanks
Old 11-12-2008, 05:16 PM
charleston charleston is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
ABS and Hub problem
I recently encountered the same issue with my 02TB. I my ABS activated just prior to stoping, I replaced the hub and it was resolved (Unfortunatly the sensor is inside the hub and cannot be serviced without replaceing the entire hub assembly). It started again after about 4000 miles. To isolate the problem, I unhooked each wheels sensor one at a time and drove around the block. being shure to go fast enough to get the ABS to acticate (They are only on the front wheels, rear is on drive shaft) It was the same hub, and the berings had allready gone bad again. If you just did this recently you can do as I did and return the part because they are usually under warranty. They replaced it for free and now all is fine again. I dont think you will hurt anything by unhooking the fuse I drove like this for 10000 miles until I initially pin pointed the problem. But you will not be able to tell if there is any other problem with the brakes because the red BRAKE light will not go off until the fuse is replaced. Also one more piece of advice. The problem will eventually go away because the sensor will fall completly apart. Then the ABS light will come on, but the funny stoping will go away. Hope this helps with your problem I pulled my hair out for a long time with this. GOOD LUCK!!!!
