Gas Tank Capacity - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-05-2008, 11:22 PM
daveyboy43 daveyboy43 is offline
2002 Chevy TrailBlazer LT
Gas Tank Capacity
Have an 03 Trailblazer and was wondering how many gallons does my gas tank hold and also is there a low fuel indicator and if there is, how many gallons are left when it comes on.
Old 11-06-2008, 09:01 AM
GA Jason's Avatar
GA Jason GA Jason is offline
2008 Chevy TrailBlazer LT
Dk Brahma Jewel Metallic 4.2L I6 2WD
I think the tank holds 18-20 gal. There is a light on the fuel gauge itself, it'll ding when you get low. As for how many gallons will be left at that point couldn't tell ya Ive never pushed it, would imagine 2-3 gal.
Old 11-06-2008, 12:31 PM
stanley2 stanley2 is offline
2003 Chevy TrailBlazer LT
Emerald Jewel Metallic 4.2L I6 2WD
Look in your glove box to see if you have the following RPO code
NNK PART PKG, EXT CAP FUEL TANK 22 GAL (83.3 L)
Bilstein HD, K&N CAI 57 with gutted air box, Alpine IVA-W205 HU GT5-4.10 gears G80, 6000K HID Lows and Fog, PCMForLess,
Old 11-06-2008, 01:22 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Since you have an 03---- you have 2 possible tank sizes...
Early models had the 18.7 gallon tank. Somewhere thru the production- they changed to the 22 gallon tank.
I have an 03- and it has the 18.7 gallon tank.
When my low fuel light comes on- and I drive to the gas station-
It will on average take 16.7 gallons to refill.
Meaning that I still have 2 gallons of fuel left in the tank when the light comes on.
Once your light comes on- I recommend you go gas up- and take note of how much it took...
Over several tank fulls- youll be able to approximate how much gas you have left.
Old 11-06-2008, 02:47 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
I drove about 15-20 (city) miles when my light came on, and i have a 18.7 Gallon tank. The light is suppose to come on when you have 2 gallons of gas or less.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 11-06-2008, 07:28 PM
bullethole's Avatar
bullethole bullethole is offline
Senior Member
Sandstone Metallic 4.2L I6 4X4
EXT models also had a larger tank. Mine has the 18.7. I have driven as far as 50 miles with the low fuel light on. Now, I swear this is true, It took 19.3 gallons to fill it up to the neck. Can you say "fumes"? However, I would not recommend that to everyone. I just know my TB.
Troubleshooting rule #1 : Check the simplest and least expensive things FIRST!
Old 11-07-2008, 11:24 AM
Robert1101's Avatar
The gas station pump might have been metering wrong. Have you ever put that much in the tank again? I have never gotten more than 18.25 to the very top of the neck.
Robert
Old 11-07-2008, 11:30 AM
Aerostud1026 Aerostud1026 is offline
Senior Member
2008 GMC Envoy Denali
Black Granite Metallic 5.3L V8 4X4
It's possible as rbarrios said to have 2 possible sizes....you can either watch the pump and if you get gas when your light is at E and it fills 18-19 or more at E then you obviously have the 22 gallon, if its only takes 15-17 gallons on E then its the 18.7 gallon tank......if you do this method I would watch 3 fill ups to see where it stops at seeing how it was already said that the gas stations pump meters might be alittle off sometimes....
Or you can just take your VIN to a local GM dealership and ask them to run it because your not sure what are the spec's, that will tell you everything, including the tank size
From this moment forward, whoever says you cant.....is now silenced
Old 11-07-2008, 01:05 PM
bullethole's Avatar
Senior Member
Metering on the pump is OK. The station owner is a friend of mine. It was really JUST EMPTY. It only happened one time.
Old 12-18-2009, 11:58 AM
arkady arkady is offline
2003 Chevy TrailBlazer LT EXT
Black 4.2L I6 4X4
I'm curious
Hi, I happen to have a 2003 Trailblazer LT EXT and I just put in 20 gallons and the low light was not on, nor was I but barely under the quater tank mark. Is it possible that I have a 25 gallon tank?
