Code P1481- with pic - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-10-2008, 04:38 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
found this on another site...
I dont have that code... but I know ive read about it on here...
Heres a pic of the most likely problem..
#05-06-02-012B: Service Engine Soon (SES) or Check Engine Light On, DTC P0480,
P0526/P1481/P1484 Set (Replace Engine Cooling Fan Wiring Harness) - (Oct 19, 2006)
Subject:
P0480/P0526/P1481/P1484 Set (Replace Engine Cooling Fan
Wiring Harness)
Models:
2004-2006 Buick Rainier
2002-2006 Chevrolet TrailBlazer, TrailBlazer EXT
2002-2006 GMC Envoy, Envoy XL
2004-2005 GMC Envoy XUV
2005-2006 GMC Envoy Denali, Envoy XL Denali
2002-2004 Oldsmobile Bravada
2005-2006 Saab 9-7X
This bulletin is being revised to add DTC P1484. Please discard Corporate Bulletin Number 05-06-02-012A (Section 06 Engine/Propulsion System).
Condition
Some customers may comment that the Service Engine Soon (SES) or Check Engine light is illuminated. This condition may be intermittent and upon investigation, the technician may find either DTC P0480, P0526, P1481 or P1484 set.
Cause
This condition may be caused by the cooling fan harness chaffing against the plastic guide it routes through. This contact may damage the insulation of the wires enclosed in that harness.
Correction
Replace the engine cooling fan harness using the procedure listed below.
Remove the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
Place the cooling fan assembly on a bench.
Disconnect the harness electrical connector from the cooling fan clutch.
Remove the harness from the plastic guide while feeding the wires out of the slot.
Before installing the new harness, wrap the affected area on the wires with electrical tape to keep the protective sleeve in place. Be sure to keep the tape approximately 25 mm (1 in) away from the connector so the wires can be fed into the slot.
Feed the wires into the slot and install the harness to the plastic guide.
Connect the harness electrical connector to the cooling fan clutch.
Install the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
Parts Information
Part Number
89024920
Description
Harness Assembly, Engine Cooling Fan Wiring
Old 10-09-2013, 06:17 PM
Vinchester Vinchester is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
Thanks for sharing good reference.
