TCCM Replacement How To - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > 4x4 Drivetrain
Old 12-13-2008, 02:41 AM
Vartz04's Avatar
Vartz04 Vartz04 is offline
2008 Chevy Silverado W/T
Summit White 4.2L I6 2WD
I purchased my TCCM from GM Parts Direct. It cost about $200 Shipped.
Here is how you replace it.
First take off the panel under the steering wheel and the pannel that is below that
This is what you will see from under neath the blue clip goes into the TCCM there are 3 different plugs that clip in there. It is right behind the metal plate that you will see when you take off the pannel, It is all the way to the drivers side.
These are the 3 plugs after you take them out of the TCCM They unclip pretty easily but require a little contortion to get your hand up there to them. I am sure you could just take more stuff off but this wasnt too bad.
This is how they go in the TCCM. Note, you cannot put them in before you pop the new TCCM into its bracket. This is just so you can see the order of the plugs because you won't be able to read the label on the TCCM when you put it into place.
Clip the TCCM into its bracket, and install the plugs. The small black plug goes all the way to the passenger side, I labeled them in the drawing.
Put the dash back together, go to the dealer and get it programed.
any questions just ask here, don't PM me
2008 Silverado Regular Cab Long Bed 2wd 4.3 V6
RIP 2002 Trailblazer 4x4 I6
Old 12-15-2008, 12:05 PM
SweetD8943 SweetD8943 is offline
2002 Chevy TrailBlazer LT
Medium Red Metallic 4.2L I6 AWD
Great info - thank you so much for posting the process.
Any trouble driving the vehicle after swapping the TCCM out?
If you can - let us know what they get you for ($$) to do the re-programming of the TCCM at the dealership.
Thanks again - exactly what I needed to get this thing replaced on our TB.
Dave
Old 12-15-2008, 12:36 PM
gordinho80's Avatar
gordinho80 gordinho80 is offline
2004 Chevy TrailBlazer LS
TCCM needs to be reprogrammed? I had an issue with mine a few months back. I was getting the Service 4WD light and the switch didnt have any indicator lights on. I swapped out the TCCM with one from ebay, No Problems since... never went to dealer...
Mario -
OffRoadTB.com
Old 12-15-2008, 12:56 PM
Mario,
Someone, somewhere had mentioned that you do not need to get the newer, redesigned TCCM "reprogrammed" - whatever they did with the redesign eliminated the need to reprogram...not sure, but it sounds like it worked for you.
It will be interesting to see what they tell Vartz04 when he goes to the dealership...thanks for the input!
Dave
Old 12-15-2008, 03:35 PM
480-Pelle's Avatar
480-Pelle 480-Pelle is offline
2002 Chevy TrailBlazer LTZ
Dark Green Metallic 4.2L I6 AWD
So did I, installed a -04 TCCM on my -02 TB...no problem.
//Pelle
Old 12-15-2008, 11:44 PM
Vartz04's Avatar
well I took mine to the dealer, they said they cannot communicate with the replacement. So something else is up I guess.
Old 12-16-2008, 10:00 AM
Hey Jeff -
That sucks. Question: Did you ever get a trouble code reading for the TCCM to diagnose it? My mechanic originally ran the diagnostic and came up with a trouble code - it was # CO-550, which came up as something to do with the TCCM / ECU. Sort of vague though...
Just wondering if you were going off of a specific diagnostic trouble code, or off the hunch that it was your TCCM based on your research of the problem?
Thanks -
Dave
Old 01-21-2009, 01:34 PM
TRAILBLAZER_GUY TRAILBLAZER_GUY is offline
I know this Thread is over a month old, however i still think we need to follow up with the question asked previously, "Does another used 02 Trailblazer Module which is in current working condition a fix to install in an 02 Trailblazer with a bad TCCM?"
The Reason i ask is because i've heard that the 02 model TCCM is not Programmable... So does that mean that after the circuit is lost, it goes into sleep mode, Forever? Please share light on this since i find it difficult to understand that after a dead battery it would not work.
Old 01-23-2009, 09:33 AM
ToddMeister ToddMeister is offline
2002 Chevy TrailBlazer LS
Red 4.2L I6 4X4
Here is what I did
I put a working TCCM from an 03 Trailblazer EXT into our 02 Trailblazer, works just fine, we did not reprogram the 03 unit. The old one out of the 02 was dead (no lights on 4WD switch/service 4wd light, dead TCCM code) I would think another working 02 TCCM would work in TB with a bad TCCM.
Old 01-27-2009, 05:36 PM
booka96 booka96 is offline
2002 tccm issue
was wondering if the 03 and 02 tccm are interchangeable on the trailblazer. is the tccm located in the same place on the 03 as the 02. my 02 is on the drivers side and looking at another website it shows a picture of it on the passenger side http://kylestubbins.com/node/11 , they look different in the pictures. any help is appreciated
