Oil pressure drop! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 12-21-2008, 06:13 PM
MIJEN05 MIJEN05 is offline
2005 GMC Envoy SLT XL
Light Pewter Metallic 5.3L V8 4X4
Oil pressure drop!
hey so i was driving down the road acouple of days ago engine light came on then a few mins latter the gaure light came on and the oil gauge was on zero i pulled over checked the oil made sure i wasnt leaking any fluid witch both where good! so i went over to autozone and checked it it said it was the oil pressor sensor but they didnt have one for it. is that something i can change? or would i be better of taking it to the shop?
any help would be great
thanks mike
Old 12-21-2008, 06:22 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Hmmm, I have an 05 as well, and I am having the same problem.
The check gauge light comes on and oil pressure at 0. As I look at (less than a sec), it climbs to normal. It's happened about 3 times in a month. The oil level is fine, I assumed a loose connection or a bad sending unit. Perhaps, you've answered my dilemma. I'll look at the repair manual to see what's involved with changing it.
Ray
Old 12-21-2008, 06:53 PM
n0kfb n0kfb is offline
1901 NYqhn UquBJ
UiO9ourI9g Other AWD
If you need to ask...
Originally Posted by MIJEN05 View Post
>snip< so i went over to autozone and checked it it said it was the oil pressor sensor but they didnt have one for it. is that something i can change? or would i be better of taking it to the shop? >snip<
If you need to ask, you are probably better off taking your truck to a shop.
-- Dan Meyer
Old 12-21-2008, 08:08 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Ok Mike, here's the poop. If you can change the oil filter, you can change the sending unit.
The sending unit is screwed into the casting above the oil filter. Unplug the connector, back out the sender and replace. That easy.
Ray
Old 12-22-2008, 12:43 AM
2003 GMC Envoy SLT
Um, are you sure about the location? MIJEN05 lists a 5.3 V8. I can find the location for our I6 but, i couldn't find it for the V8. Unless I missed something.
Old 12-22-2008, 12:53 AM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Isn't the Oil sender on a 5.3 on the left head near the front?
Brendan,
PCMFORLESS Tune, CAI, HID's, PIAA's, Mirror Signals, Glasspack & Tip
Old 12-22-2008, 01:00 AM
2003 GMC Envoy SLT
That sounds right. I looked in my '02 Helm manual but couldn't find a listing for the 5.3 oil sending unit.
Old 12-22-2008, 08:09 PM
thanks for the respons guys! i noticed that your calling it a sender not a sensor is that right? ( maybe thats why couldnt find anything on it
i'll try sender see what i can find.
Old 12-22-2008, 08:23 PM
so ive been looking around i found an oil sensor but from what i can tell its for the oil level and when i search for sendor theres not much on that! does anyone know where the best place to get the part? i havent had time to run over to the local parts store. butits been going on for a couple weeks
Old 12-22-2008, 08:52 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Sorry, missed the v8 part.
I can not find it either, looked all over the web. Vague reference to it being located on the front top, driver's side.
Yep, it's a sending unit........it sends pressure info to a receiving device.
Ray
